Oscillator Footprints
I am new to KiCad and on my first PCB. Among other things, on there is an oscillator (Q8.0-SS4-30-30/30-LF (Jaunch), picture shows it’s specsheet). I have a problem that I cannot find the appropriate footprint (I only have the Crystals library installed that is by default). So my question would be where I could find the footprint of this oscillator or if it already is in the Crystals library?
Thanks in advance,
Burek
Based on the dimensions in the drawing It seems that it fits any HC-49 footprint (the most common one for crystals). If you want the 3D model to match the device I’d suggest Crystal_HC49-4H_Vertical.
You can use the measure tool (Ctrl+Shift+M by default) to check dimensions of the footprint to see if they match.
I see, I checked and it fits perfectly, thank you so much for your help.
