version: 6.99 nightly
– The C compiler identification is GNU 9.3.0
[cmake] – The CXX compiler identification is GNU 9.3.0
[cmake] – Check for working C compiler: /usr/local/gcc-9.3.0/bin/gcc
[cmake] – Check for working C compiler: /usr/local/gcc-9.3.0/bin/gcc - works
[cmake] – Detecting C compiler ABI info
[cmake] – Detecting C compiler ABI info - done
[cmake] – Detecting C compile features
[cmake] – Detecting C compile features - done
[cmake] – Check for working CXX compiler: /usr/local/gcc-9.3.0/bin/g++
[cmake] – Check for working CXX compiler: /usr/local/gcc-9.3.0/bin/g++ - works
[cmake] – Detecting CXX compiler ABI info
[cmake] – Detecting CXX compiler ABI info - done
[cmake] – Detecting CXX compile features
[cmake] – Detecting CXX compile features - done
[cmake] – KiCad install dir: </home/bzdr/kicad/build/debug/install>
[cmake] – Looking for malloc.h
[cmake] – Looking for malloc.h - found
[cmake] – Looking for iso646.h
[cmake] – Looking for iso646.h - found
[cmake] – Looking for stdint.h
[cmake] – Looking for stdint.h - found
[cmake] – Looking for strcasecmp
[cmake] – Looking for strcasecmp - found
[cmake] – Looking for strncasecmp
[cmake] – Looking for strncasecmp - found
[cmake] – Looking for strtok_r
[cmake] – Looking for strtok_r - found
[cmake] – Looking for malloc - found
[cmake] – Looking for math.h
[cmake] – Looking for math.h - found
[cmake] – Looking for C++ include cmath
[cmake] – Looking for C++ include cmath - found
[cmake] – Looking for asinh
[cmake] – Looking for asinh - found
[cmake] – Looking for acosh
[cmake] – Looking for acosh - found
[cmake] – Looking for atanh
[cmake] – Looking for atanh - found
[cmake] – Performing Test HAVE_CMATH_ISINF
[cmake] – Performing Test HAVE_CMATH_ISINF - Success
[cmake] – Looking for clock_gettime in rt
[cmake] – Looking for clock_gettime in rt - found
[cmake] – Looking for gettimeofday
[cmake] – Looking for gettimeofday - found
[cmake] – Looking for getc_unlocked
[cmake] – Looking for getc_unlocked - found
[cmake] – Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE
[cmake] – Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE - Success
[cmake] – Enabling warning -Wsuggest-override
[cmake] – Performing Test COMPILER_SUPPORTS_WINCONSISTENT_MISSING_OVERRIDE
[cmake] – Performing Test COMPILER_SUPPORTS_WINCONSISTENT_MISSING_OVERRIDE - Failed
[cmake] – Performing Test COMPILER_SUPPORTS_WDUPLICATED_BRANCHES
[cmake] – Performing Test COMPILER_SUPPORTS_WDUPLICATED_BRANCHES - Success
[cmake] – Enabling warning -Wduplicated-branches
[cmake] – Performing Test COMPILER_SUPPORTS_WDUPLICATED_COND
[cmake] – Performing Test COMPILER_SUPPORTS_WDUPLICATED_COND - Success
[cmake] – Enabling warning -Wduplicated-cond
[cmake] – Performing Test COMPILER_SUPPORTS_WVLA
[cmake] – Performing Test COMPILER_SUPPORTS_WVLA - Success
[cmake] – Enabling error for -Wvla
[cmake] – Performing Test COMPILER_SUPPORTS_WIMPLICIT_FALLTHROUGH
[cmake] – Performing Test COMPILER_SUPPORTS_WIMPLICIT_FALLTHROUGH - Success
[cmake] – Enabling warning -Wimplicit-fallthrough
[cmake] – Performing Test COMPILER_SUPPORTS_WRETURN_TYPE
[cmake] – Performing Test COMPILER_SUPPORTS_WRETURN_TYPE - Success
[cmake] – Enabling error for -Wreturn-type
[cmake] – Performing Test COMPILER_SUPPORTS_WSHADOW
[cmake] – Performing Test COMPILER_SUPPORTS_WSHADOW - Success
[cmake] – Enabling warning -Wshadow
[cmake] – Performing Test COMPILER_SUPPORTS_WSIGN
[cmake] – Performing Test COMPILER_SUPPORTS_WSIGN - Success
[cmake] – Enabling warning -Wsign-compare
[cmake] – Performing Test COMPILER_SUPPORTS_WMISSING_INIT
[cmake] – Performing Test COMPILER_SUPPORTS_WMISSING_INIT - Success
[cmake] – Enabling warning -Wmissing-field-initializers
[cmake] – Performing Test COMPILER_SUPPORTS_WEMPTY_BODY
[cmake] – Performing Test COMPILER_SUPPORTS_WEMPTY_BODY - Success
[cmake] – Enabling warning -Wempty-body
[cmake] – Performing Test COMPILER_SUPPORTS_WREORDER
[cmake] – Performing Test COMPILER_SUPPORTS_WREORDER - Success
[cmake] – Enabling warning -Wreorder
[cmake] – Performing Test COMPILER_SUPPORTS_WMISMATCHED_TAGS
[cmake] – Performing Test COMPILER_SUPPORTS_WMISMATCHED_TAGS - Failed
[cmake] – Performing Test COMPILER_SUPPORTS_WIMPLICIT_FLOAT_CONVERSION
[cmake] – Performing Test COMPILER_SUPPORTS_WIMPLICIT_FLOAT_CONVERSION - Failed
[cmake] – Performing Test COMPILER_SUPPORTS_WPSABI
[cmake] – Performing Test COMPILER_SUPPORTS_WPSABI - Success
[cmake] – Disabling warning -Wpsabi
[cmake] – Configuring KiCad for the wxGLCanvas EGL backend
[cmake] – Found Gettext: /bin/msgmerge (found version “0.19.8.1”)
[cmake] – Found OpenGL: /usr/lib64/libOpenGL.so
[cmake] – Found OpenGL EGL library: /usr/lib64/libEGL.so
[cmake] – Found GLM: /usr/include (found suitable version “0.9.8.6”, minimum required is “0.9.8”)
[cmake] – Found ZLIB: /usr/lib64/libz.so (found version “1.2.7”)
[cmake] – Check for installed ZLIB – found
[cmake] – Found CURL: /usr/lib64/libcurl.so (found version “7.29.0”)
[cmake] – Found PkgConfig: /bin/pkg-config (found version “0.27.1”)
[cmake] – Checking for module ‘cairo’
[cmake] – Found cairo, version 1.15.12
[cmake] – Found Cairo: /usr/lib64/libcairo.so (found suitable version “1.15.12”, minimum required is “1.12”)
[cmake] – Checking for module ‘pixman-1’
[cmake] – Found pixman-1, version 0.34.0
[cmake] – Found Pixman: /usr/lib64/libpixman-1.so (found suitable version “0.34.0”, minimum required is “0.30”)
[cmake] – Found Boost: /usr/local/lib/cmake/Boost-1.78.0/BoostConfig.cmake (found suitable version “1.78.0”, minimum required is “1.59.0”)
[cmake] – Found Freetype: /usr/lib64/libfreetype.so (found version “2.8.0”)
[cmake] – Found the following HarfBuzz libraries:
[cmake] – HarfBuzz (required): /usr/lib64/libharfbuzz.so
[cmake] – Found HarfBuzz: /usr/include/harfbuzz (found version “1.7.5”)
[cmake] – Found Fontconfig: /usr/lib64/libfontconfig.so (found version “2.13.0”)
[cmake] – Found OCC: /usr/local/occt/include/opencascade (found version “7.6.0”)
[cmake] – Found OpenCASCADE Standard Edition version: 7.6.0
[cmake] – ++ OpenCASCADE Standard Edition include directory: /usr/local/occt/include/opencascade
[cmake] – ++ OpenCASCADE Standard Edition shared libraries directory: /usr/local/occt/lib
[cmake] – Found SWIG: /usr/local/bin/swig (found suitable version “4.0.2”, minimum required is “3.0”)
[cmake] – pybind11 v2.7.1
[cmake] – Found PythonInterp: /usr/local/bin/python3 (found version “3.6.8”)
[cmake] – Found PythonLibs: /usr/local/python3.6.8/lib/libpython3.6m.so
[cmake] – Performing Test HAS_FLTO
[cmake] – Performing Test HAS_FLTO - Success
[cmake] – Found PythonInterp: /usr/local/bin/python3 (found suitable version “3.6.8”, minimum required is “3.6”)
[cmake] – Check for installed Python Interpreter – found
[cmake] – Python module install path: lib/python3.6/site-packages
[cmake] – Found PythonLibs: /usr/local/python3.6.8/lib/libpython3.6m.so (found suitable version “3.6.8”, minimum required is “3.6”)
[cmake] – Found Phoenix 4.1.1/gtk3 (wxWidgets 3.1.5)
[cmake] – Found wxWidgets: -L/usr/local/wxWidgets-3.1.5/lib;-pthread;;;-lwx_gtk3u_gl-3.1;-lwx_gtk3u_aui-3.1;-lwx_gtk3u_html-3.1;-lwx_gtk3u_core-3.1;-lwx_baseu_net-3.1;-lwx_baseu-3.1;-lwx_gtk3u_propgrid-3.1;-lwx_baseu_xml-3.1;-lwx_gtk3u_stc-3.1;-lwx_gtk3u_richtext-3.1 (found suitable version “3.1.5”, minimum required is “3.1.5”)
[cmake] – Found Doxygen: /bin/doxygen (found version “1.8.5”) found components: doxygen missing components: dot
[cmake] – Found UnixCommands: /bin/bash
[cmake] – Checking for module ‘gtk±3.0’
[cmake] – Found gtk±3.0, version 3.22.30
[cmake] – S3DSG version: 2.0.0
[cmake] – Found Boost: /usr/local/lib/cmake/Boost-1.78.0/BoostConfig.cmake (found version “1.78.0”) found components: unit_test_framework filesystem system
[cmake] – Found wxWidgets: -L/usr/local/wxWidgets-3.1.5/lib;-pthread;;;-lwx_gtk3u_gl-3.1;-lwx_gtk3u_aui-3.1;-lwx_gtk3u_html-3.1;-lwx_gtk3u_core-3.1;-lwx_baseu_net-3.1;-lwx_baseu-3.1;-lwx_baseu_xml-3.1;-lwx_gtk3u_stc-3.1 (found suitable version “3.1.5”, minimum required is “3.0.0”)
[cmake] – Configuring done
[cmake] CMake Warning (dev) at thirdparty/3dxware_sdk/CMakeLists.txt:33 (add_library):
[cmake] Policy CMP0063 is not set: Honor visibility properties for all target
[cmake] types. Run “cmake --help-policy CMP0063” for policy details. Use the
[cmake] cmake_policy command to set the policy and suppress this warning.
[cmake]
[cmake] Target “TDxNavlib” of type “STATIC_LIBRARY” has the following visibility
[cmake] properties set for CXX:
[cmake]
[cmake] CXX_VISIBILITY_PRESET
[cmake] VISIBILITY_INLINES_HIDDEN
[cmake]
[cmake] For compatibility CMake is not honoring them for this target.
[cmake] This warning is for project developers. Use -Wno-dev to suppress it.
[cmake]
[cmake] – Generating done
click the scripting console button , the report err :
