Hi, I’m new to KiCad.
Is it possible to auto-route a multi layer board so that the top layer only has component pads joined to vias and the rest of the layer is a copper pour? In other words each smd pad will go straight to a via and therefore there will be be no long tracks on the top layer. The reason for this is to achieve a ground plane on the top layer.
If this is possible, how would you do this?
Any comments would be much appreciated.
