I’ve never come across a polarized relay coil winding before.
Anyone know why these are now a thing?
My one guess is that there is some extra circuit for flyback and de-bounce already inside the device.
Anyone?
Anyone?
The data does not show any diode, but they do have Latching versions (single coil) and for those, you certainly do need polarity - looks like that info is included on all the drawings.
There might be some slight magnetic biasing, but they do not show both drive directions.
You might need to test a relay carefully, to see if you can measure any asymmetry.
In the meantime, just follow the polarity markings.
I found this and it says the difference is the use of permanent magnets in polarized versions.
Opps: I just found this edit didn’t save last night.
Debounce is listed here:https://www3.panasonic.biz/ac/ae/control/relay/power/difference/index.jsp
It has been quite a few years, but I DO recall seeing relays with internal freewheeling diodes. I don’t recall how that information was represented in the Data Sheet, or schematic symbol.
In the mid 1980’s I helped design a system that used magnetically latched relays to “remember” the state of some front-panel controls in case of power loss. You energized the relay with one polarity to activate the contacts, and with the opposite polarity to deactivate them. As I recall, the concept was rather effective in the days when there wasn’t any truly electronic non-volatile memory, with more than a few hundred write cycles.
Dale
I have used polarized telecom relays in the past. The built in magnet reduces the operating current.
I’ve also used latching relays in circuits for a mix-match of these reasons:
I’ll admit, mostly corner cases…
