ODB++ vias missing in export
if you have just Vias in your design and no other plated through holes, the Vias are completely missing in the ODB++ export. If you just add one other plated through hole like a mounting hole in my example the vias are exported correctly. I have attached my test project. To reproduce it, just populate the mounting hole on the pcb or remove it by the “exlude from PCB” checkbox. I have also included the two ODB++ variants. “with” is with plated through hole and “without” ist without plated throgh hole and therefore without vias in the ODB++ export file.
My ODB++ viewer is PCB-Investigator 15.1.0 from easylogix. A picture of the missing drill layer is seen here:
via_odb_test.zip (332.0 KB)
Application: KiCad x64 on x64
Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
Platform: Windows 11 (Erzeugungsversion 22631), 64-bit Edition, 64 bit, Little endian, wxMSW
Date: Feb 19 2025 17:46:53
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: de_DE
Enc: UTF-8
Num: 1.234,5
if someone can verify, i think that this is a very important issue and need to be reported on gitlab
ps.
i think i can confirm that:
KiCad never cease to amaze me.
Try expecting the same response time from a big $$ cad! (23h from discovery to fix)
That’s crazy, KiCad and its community is awesome! :rocket:
