ODB++ jobset export filename
Jobset ODB++ export always produces a [projectname].zip. Even while selecting compression format “None” the text [zip] appears in the directory name.
Providing a path and/or project variables in the filename field does not behave the same as with other output options like 3D model export. The filename field seems to be ignored completely.
Application: KiCad x64 on x64
Version: 9.0.1, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) Iris(R) Xe Graphics, 4.6.0 - Build 32.0.101.6314
Date: Mar 30 2025 01:11:30
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_NL
Enc: UTF-8
Num: 1.234,5
This sounds like a bug. You should probably check if it’s been reported already, and report it if it hasn’t. Before you do, make sure its present in the latest nightly build.
There’s a shortcut for bug reporting in the Help menu, might be in the about window, I don’t remember exactly.
I think you have encountered the same question as me, and I found a similar issue on GitLab. I’m not sure if it was intentional or if there was indeed a bug, you can take a look, but it seems that the developers don’t have time to deal with this matter.
作业集 PDF 输出始终具有相同的文件名 (#20474) ·问题 ·kicad/代码/kicad — jobset pdf outputs always have the same filename (#20474) · Issue · kicad/code/kicad
