During the last couple of days I have been fighting with an issue. I attempted to add text to a symbol, but when I finished the process the text vanished.
I cannot easily show the problem right now, as I have experimentally fixed it using Notepad. But in the image below, the portion of “experimental text” that was within the rectangle was invisible. This is a view from within the symbol editor:
Based on my fix in notepad, It seems that the parameter in question was no fill versus black fill for the symbol rectangle. Apparently the added text gets rendered behind the fill color. That does not make obvious sense.
I do see preferences > “Use schematic editor color theme” but how does that affect a symbol which I have recently/previously created?
Another confusion factor: In notepad it seems that my symbol definition “Test_Symbol_01” is (followed) by symbol “Test_Symbol_01_1_1.” I first tried setting the first fill color definition to “no fill” but that did not work. I then found the second symbol definition and also needed to set that fill color definition to “no fill”. I am glad my name is not “Phil.”
What is the normal/correct way to work this?
In the text editor, I noticed a fill color (for this symbol) of 0,0,0 but I cannot figure out the normal way to edit that from symbol editor?
EDIT: In fact I do have an original symbol (I do not want to show that one) on which the problem is not fixed. When I tried inserting that into a schematic diagram, there is absolutely nothing visible within the symbol rectangle. No pin names, no reference designation, nothing…
Application: KiCad Symbol Editor x64 on x64
Version: 8.0.2, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Date: Apr 27 2024 23:05:17
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.5.0-DEV
ngspice: 42
