Is it possibile to add a signature to a set of via objects (to identify them among others)?
Not really.
That said, the python interface is powerful and you can hack around it. For example, you could use a starting sequence (e.g. 123456) that uniquely identifies your via group and then assign them to sequential timestamps that all begin with the same sequence.
You won’t be able to see this value in the UI, however, so depending on your usecase, this may not be what you are looking for.
uhm… thnx for the hint . I’ll try to understand how to make this… not seeing all this mess in the UI should be fine
you can also have a look at the via stitching code
Yess!! It worked! Thank you!
