Novel (?) Combi Footprint and symbol using it
I am working on this board design. I am designing it to be flexible (multiple possible BOMs such as FET or NPN power transistors.) And I have this additional NPN where I want to be able to use a SOT23 or SOT223 or bypass with a 0 ohm 1206 resistor.
Yesterday I was editing the board layout to connect the 1206 resistor collector-emitter to my NPN combi footprint. But today I realized that I will only use one of the three in an assembled board. So I have further edited my SOT23-SOT223 footprint to add the resistor option. And I have a symbol which I am calling “QR” to indicate transistor or resistor. This will save significant board space and ease routing on this 2-layer board as compared to a separate footprint for the resistor.
When working on the footprint, I realized that it can easily fit the resistor connected between any two pins. But this symbol shows only the collector-emitter resistor because that is the only option I anticipate in this circuit design.
Bobs_SOT23_SOT223_1206_Special_Combi_01.kicad_mod (2.7 KB)
So you associate this combined footprint with all three symbols and then set them Do not fit or Fit depending on which variant you are using ?
I don’t see any benefits just downsides I’m afraid . . . why not simply use the correct footprints for the devices used but arrange them in the same way as you have for your singular footprint ?
If you overlay multiple footprints on the same pads or courtyard during PCB layout, that gives you DRC errors. Perhaps added difficulties when routing tracks. A combi footprint ought not do that.
I agree you will not get DRC errors, but they can be set to be ignored in that instance. If the combination of 3 footprints is the same as the combined footprint the tracking is exactly the same.
With the combined foot print you have “incorrect” footprint info for 3 components, you have one reference on the PCB (assuming it’s used) for 3 components (no SOT23, SOT223 or 1206 footprint ref in the BOM) I don’t see any benefits, just drawbacks . . .
I do not understand what that means. I know (and the BOM can know) that one of three different component packages can be placed there, according to the build version.
Avoiding the DRC errors seems like a significant advantage.
Especially if I am doing this in multiple instances on a board, it seems like a significant help.
You have three devices, SOT23, SOT223 and 1206 but you don’t have those footprints for those devices, so you are technically using an incorrect footprint for them . . . thats all I meant.
I’d sacrifice the DRC errors to have correct reference markers on the silkscreen and correct footprints and references in the BOM.
What will you do for the symbol references ?
I think that overlaying the physical footprints causes some violation of the most conservative practice, regardless of whether we do it in the pcb editor or in the footprint editor.
For a board that is for my own use, I can easily determine whether there is significant downside. If I were doing this with a board that is to be commercially manufactured and used, I would need to discuss it with the manufacturing engineers.
My reference designation is “QR__” to indicate a transistor or a resistor (probably a 0 ohm jumper). For example, “QR21”.
And the BOM would indicate any one of these three at QR21 (for example):
0 ohms 1206
PZT4401 (NPN in SOT223)
MMBT4401 (NPN in SOT23)
This board in question is for my own use. But if it were to be commercially manufactured, I could probably submit drawings to indicate how these three different device packages would fit onto the one footprint. If the manufacturing engineer gave me a thumbs down, well fire him (or her) and find a new manufacturing engineer. (I am kidding.)
One thing I know is that I am not the originator of this sort of thinking. When I was an apps engineer, my manager recommended using one combi footprint for small MOSFETs in either 3 pin SOT23 or SOT-6 (6 pin SOT23). The odd thing is that one package would be rotated 90 degrees relative to the other. I use such a footprint to accommodate either package.
I do find this kind of issue hard to really know what is the best thing to do, hence my readiness to discuss it in the hope that I learn something new :wink:
