I’m working on a project to build a board using the espressif libraries on Debian 12, bookwork. Unfortunately even the version of KiCad on Debain is even too old for the version 6 libraries, so I have found the need to build from source.
Checking out the commit on the version 6 development branch.
2bc8c0ace5e927bc7a5bd7a630d436f488e79a38
and building with cmake. Yikes!
Eventually you will come across
*** OpenCascade library missing ***
Could not find a library for TKBinXCAF at /usr/lib/x86_64-linux-gnu
Verify your OpenCascade installation or pass CMake
the library directory as '-DOCC_LIBRARY_DIR=<path>'
CMake Error at CMakeModules/FindOCC.cmake:192 (message):
Call Stack (most recent call first):
CMakeLists.txt:741 (find_package)
This is fundamentally a Debian issue, so the way to fix it is to download the package liboce-ocaf11. Although this package downloads the libraries, it does not create the symbolic links /usr/lib/x86_64-linux-gnu/libTKBinXCAF.so to point to /usr/lib/x86_64-linux-gnu/libTKBinXCAF.so.7. But the KiCad build process let’s us work around this.
mkdir libhints
cd libhints/
ln -s /usr/lib/x86_64-linux-gnu/libTKBinXCAF.so.7 libTKBinXCAF.so
ln -s /usr/lib/x86_64-linux-gnu/libTKIGES.so.7 libTKIGES.so
ln -s /usr/lib/x86_64-linux-gnu/libTKMeshVS.so.7 libTKMeshVS.so
ln -s /usr/lib/x86_64-linux-gnu/libTKOpenGl.so.7 libTKOpenGl.so
ln -s /usr/lib/x86_64-linux-gnu/libTKSTEP209.so.7 libTKSTEP209.so
ln -s /usr/lib/x86_64-linux-gnu/libTKSTEPAttr.so.7 libTKSTEPAttr.so
ln -s /usr/lib/x86_64-linux-gnu/libTKSTEPBase.so.7 libTKSTEPBase.so
ln -s /usr/lib/x86_64-linux-gnu/libTKSTEP.so.7 libTKSTEP.so
ln -s /usr/lib/x86_64-linux-gnu/libTKSTL.so.7 libTKSTL.so
ln -s /usr/lib/x86_64-linux-gnu/libTKTObj.so.7 libTKTObj.so
ln -s /usr/lib/x86_64-linux-gnu/libTKTopAlgo.so.7 libTKTopAlgo.so
ln -s /usr/lib/x86_64-linux-gnu/libTKV3d.so.7 libTKV3d.so
ln -s /usr/lib/x86_64-linux-gnu/libTKVRML.so.7 libTKVRML.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXCAF.so.7 libTKXCAF.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXDEIGES.so.7 libTKXDEIGES.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXDESTEP.so.7 libTKXDESTEP.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXMesh.so.7 libTKXMesh.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXmlL.so.7 libTKXmlL.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXml.so.7 libTKXml.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXmlTObj.so.7 libTKXmlTObj.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXmlXCAF.so.7 libTKXmlXCAF.so
ln -s /usr/lib/x86_64-linux-gnu/libTKXSBase.so.7 libTKXSBase.so
In the file FindOCC.cmake
Set the line
find_library(OCC_TEMP_LIB ${lib} HINTS ${OCC_LIBRARY_DIR} NO_DEFAULT_PATH)
to
find_library(OCC_TEMP_LIB ${lib} HINTS ${OCC_LIBRARY_DIR} ${OCC_HINT}
NO_DEFAULT_PATH)
Then you can go back to your build directory and run
cmake .. -DOCC_HINT=[Absolute-Path-to-KiCad-Project]/libhints/
