Hi.
I would like to give my manufacturer a layer with information for creating a stencil. I would like to do this with the ECO layer. But when I plot the gerbers, the layer is empty.
Is there something I’m missing?
Kind regards
Stencils are usually derived from F.Paste and B.Paste
ECO1 & 2 stands for Engineering Change Order and is typically used for design notes
Why the ECO layer and not F.paste or B.paste that are intended for solder paste?
Do you have any drawings in the ECO layers?
Hi.
Thanks for your answer.
I have no drawing in the ECO layer.
The solderpad of a XHP35HI LED looks different than the stencil pattern (see datasheet). That’s why I want those as two different layers.
And KiCAD treats them separately as well.
x.SolderMask is for what they call ‘PCB Solder Pad’ (= the holes in the soldermask)
x.Paste is for what they call Stencil Pattern (= the holes in the stencil)
You might want to check out this thread for an example how it works:
Well, if there is nothing in the ECO layer, is normal that the gerber ECO layer is empty.
I have seen the datasheet. No need of 2 different layers.
- Make the central pad as 3 different pads put together. In the pad properties, set the solder paste clearance.
- Or make the central pad as 3 different pads with some distance between them and fill the gaps with a thick track. Also here set the pad solder paste clearance as needed.
In both cases, give the 3 central pads the same pin number.
Hi.
Thank you for your help.
I have now created the stenicl pattern as pads in the F.paste layer and underneath the footprint as pads in F.Cu layer.
