Noob question - Getting the 3D models to work on components
I have just switched to KiCAD after decades of Eagle/Autocad. This is my first project, and first post.
My design has an audio jack, that I found in the default library.
However, the 3D model in the default library is incorrect.
When I download a new model from the manufacturer, and try and replace it it, nothing appears.
Any pointers to how I can debug it?
The device is an SJ-3523-SMT (https://www.sameskydevices.com/product/interconnect/connectors/audio-connectors/jacks/sj-3523-smt-tr)
I downloaded the 3D model from the website as an STL file.
When I try and load it in the Footprint Editor, nothing appears.
How do I debug why the new model fails to load? is there a debug log, or error message somewhere?
All images combined in to one picture, as noobs, can only imbed one image :slight_smile:
Top: Default incorrect 3D model
Middle: Blank preview when I try to apply new model.
Bottom: What the new model should look like from the manufacturers website.
Thanks!
Jon.
Use the “STEP AP214 (.step)” model, not STL.
KiCad doesn’t support STL.
Looking at Connector_Audio:Jack_3.5mm_CUI_SJ-3523-SMT_Horizontal footprint, the default 3D model path is
${KICAD8_3DMODEL_DIR}/Connector_Audio.3dshapes/Jack_3.5mm_CUI_SJ-3523-SMT_Horizontal.wrl
Jack_3.5mm_CUI_SJ1-3523N_Horizontal.step which you seem to have selected is a model for a different component.
both Jack_3.5mm_CUI_SJ1-3523N_Horizontal.step & Jack_3.5mm_CUI_SJ1-3523N_Horizontal.wrl render the same incorrect part for me?
Perfect !! Thanks for the quick reply.
That worked perfectly.
Thanks.
Jon.
I’ll try and work out how to submit this solution back to the default library as a pull request. But thats for another day :slight_smile:
The default library looks correct to me.
There’s two footprints:
  • Jack_3.5mm_CUI_SJ1-3523N_Horizontal
  • Jack_3.5mm_CUI_SJ-3523-SMT_Horizontal
Jack_3.5mm_CUI_SJ-3523-SMT_Horizontal definitely does not have
Jack_3.5mm_CUI_SJ1-3523N_Horizontal.wrl (or .step) model assigned by default in my 8.0.5 installation.
Jack_3.5mm_CUI_SJ1-3523N_Horizontal has the correct model:
Manufacturer’s 3D models are generally restricted by licenses so can’t be added to the default KiCad library. But someone can re-model them, then it’s acceptable.
Ok. I must have allocated the other model by mistake while I was tinkering, trying to find out why the one I was using had no model :slight_smile:
I’ll try and knock up an OpenSCAD model to give back to the default library.
Thanks for the explanation.
Jon.
OpenSCAD is used primarily for 3D printing, so it can’t export STEP natively.
Making it in FreeCAD would be a better option.
Maybe this link helps a little bit:
