What is the “best” way to mark components as “Non-Populated” so they don’t show up in the BOM, Pick&Place file and the 3D view? Is there a simple solution or is file editing required?
For the Pick&place position file it is easy: in the footprint’s properties window (pressing “E” while over the footprint in the pcb editor) you have the “Attributes” section. Choosing “Normal+Insert” will make the footprint appear in the *.pos file (File > Fabrication Outputs > Footprint Position file)
Don’t know how accomplish the same with the BOM or 3D though, maybe somebody knows this part better than me…
That would depend on who is doing the manufacturing process and their preferences. The company where I work likes to see “100K DNS” in the value field for a 100K resistor that is “do not stuff” or simply “DNS”. This translates well to the BOM.
I usually just edit the part number and append it with “-DNP” at the end. That way, it becomes a separate part from the original. Then I note it on BOM as “DNP” and highlight. The assembler then knows that it is not supposed to be placed even though it is on the pick and place file(s).
