SW_molla_slotted_B.kicad_mod (50.5 KB)
“Why do you want to make it non-plated”. In my opinion my question was “how-to”, not philosophical. Really… “why”… hmm… “I can make plated hole and drill it non-plated-manually…hmm”… “no…”…“why”… “why I make any work? Better I go to home and do nothing”…
:D.
But, in real life, I can show what happen, when solder this component throu-hole in real world. So it is reason. My question is real problem, and this fault was Kicad 5, 6 and 7. Philosophically right answer is “use any other cad”. But if I want do this with Kicad, I must ask.
Ok, I attach it footprint (from Kicad 7).
I want three 1,8 mm non-plated hole, one 1,6 mm non-plated hole, one 2,5 mm non-plated hole. Copper on both side (and again, YES). I need rectangle non-plated hole (and this answer is round work also but reason of practice I make rect).
So:
- 1,8 mm NPTH hole without copper
- TOP COPPER. Around it 1,8 mm hole 2,4 x 2,4 mm rectangle and suitable circle. Test good width of the circle and rectangle (line width) and then fill empty areas with filled rectangle. RESULT: 2,4 x 2,4 mm filled rectangle, 1,8 mm hole and a little gap (0,05 mm about) between hole and copper.
- Then add 1 little SMD-pad inside copper area and “Edit pad as graphic shapes”. Result: TOP COPPER rectangle pad 2,4 x 2,4 mm with solder mask open 2,4 x 2,4 mm with 1,8 mm non-plated hole.
- Then, add same SMD-pad with same number to shape corners —> this make possible route from pad any point.
- NOW this special pad is on TOP COPPER. COPY it same and move it to BOTTOM, so, make just same but put it to bottom side.
FINAL RESULT: 2,4 x 2,4 mm rectangle pad, solder mask open both side, copper on both side, 1,8 mm non-plated hole.
NEXT: Copy this to other pads.
(And how I make this in it other Cad, I know anyone recommend it. Pads make it this way: PAD, Pad stack, rectangle 2,4x2,4 mm on top, same on bottom, 1,8 mm hole and “plated”-selection off…)
So… I ask real life help, not philosophical “why you need it” :D.
