It seems, that KiCad v8 does not check the minimum width of a net class. Here the NetClass “GND” is mapped to the nets “GND” and “led”. So both nets are required to have 2mm minimum width.
In the Layout, the net “led” has 0,5mm with and the net “GND” has 1mm and 2mm.
Clearly the DRC should bring up an error, but it doesn’t:
First, the netclass GND isn’t probably applied to the net “led” unless it’s a global label. Check out what the panel “Nets matching GND” says for the “led” row. If you have used a local label, you should prepend the name in the list with ‘/’ or use a wildcard.
Then for the minimum width. You can select a track segment which belongs to a net and use Inspect → Constraints Resolution. It will show which rule is effective. I tested this, and the netclass width isn’t actually “minimum” width, it’s “optimal”. Whether that’s the only good interpretation can be debated. But it’s quite normal to use a width which is “minimum where possible” while going under it if necessary, for example in tight places. Notice also that the netclass widths aren’t manufacturing constraints strictly speaking. Design Rules → Constraints, on the other hand, are hard minimum values which come from the manufacturing capabilities.
If you want to force the value as minimum you can set up a Custom Rule.
This isn’t a bug. As per previous answers, the track width specified on the netclass isn’t a minimum, it’s the optimum. The correct way to check for a minimum track width is per the answer @eelik has given above.
