pigeon
August 5, 2023, 12:21pm
1
Get this pop up error when I try and export step files:
Loading board
Determining PCB data
Board Thickness from stackup: 1.600 mm
Build STEP data
Add component REF**.
Create PCB solid model
Board outline: find 73 initial points
Build board main outline 1 with 73 points.
OCC exception: BRepAdaptor_Curve::No geometry
OCC error adding main outline polygon 1 with 73 points.
Build board cutouts and holes (55 hole(s)).
Generate board full shape.
Writing STEP file
No valid PCB assembly; cannot create output file 'E:\path to my file.step'.
** Error writing STEP file. **
Does it show OK in the 3D viewer ? if not that might give you additional hints to what is the problem . . . but it might be related to these lines . . .
pigeon
August 5, 2023, 1:18pm
3
Yes, shows up totally fine in 3D View. it is a bit of a funky shape but 3D viewer has no issue with it.
pigeon
August 7, 2023, 8:19pm
4
BUMP (hope that’s not a bannable offence?)
I recommend you report a bug on gitlab with your board attached
3ric
September 13, 2023, 1:37pm
6
Probably you already fixed this, but I had the same problem.
I had a non-contiguous board outline, apparently.
I fixed it by selecting each segment and moving the endpoint
until it snapped to the adjacent one.
You can also run DRC and it will point out exactly where the outline is discontinuous.
system
Closed
January 18, 2024, 8:15am
9
