Thanks. I took a look and nothing is listed, but yest there is the yellow triangle. Here is the response I get when I click it:
File “/usr/lib/python3.8/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1014, in _gcd_import
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 671, in _load_unlocked
File “”, line 848, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/usr/share/kicad/scripting/kicad_pyshell/init.py”, line 20, in
import wx
File “/usr/lib/python3/dist-packages/wx/init.py”, line 12, in
version = wx.version.VERSION_STRING
AttributeError: partially initialized module ‘wx’ has no attribute ‘version’ (most likely due to a circular import)
File “/home/graham/.local/share/kicad/6.0/3rdparty/plugins/com_gitlab_dennevi_Board2Pdf/init.py”, line 1, in
from .board2pdf_action import board2pdf
File “/home/graham/.local/share/kicad/6.0/3rdparty/plugins/com_gitlab_dennevi_Board2Pdf/board2pdf_action.py”, line 7, in
import wx
File “/home/graham/.local/share/kicad/6.0/3rdparty/plugins/org_openscopeproject_InteractiveHtmlBom/init.py”, line 6, in
import wx
