No libraries after fresh install on Windows E:/ drive
Another variant of this everlasting issue here.
Windows 7, KiCad 5.1.9 (German)
Perfectly worked on my mac but here on windows hassles.
I installed a freshly downloaded version to the E:/ drive.
Nevertheless. After installing all the paths directed to non-existing locations on the C:/ drive.
So I manually set them to the locations where all the libraries are. Used the folder icon to browse to the folders to avoid spelling errors.
Doublechecked if the files are there and they are.
KiCad runs nicely but the Libraries for parts and modules seem not to be found. When I open the
When opening the library it seems to be empty. Also after a while, it simply stays empty. The folders where the directories point to are full of files. Like the library folder i.e. looks like:
4xxx.dcm 7kB
4xxx.lib 59kB
4xxx_IEEE.dcm 1kB …
Of course, I already tried to reinstall and restart the software after any changes.
Any ideas someone? :roll_eyes:
The fact you had nonexisting locations in path variables tells me you probably have a config from previous installation still in %APPDATA%\kicad
Remove that folder to start from a clean state, kicad will automatically pick up it’s own libraries.
Thank you @qu1ck. If I only knew where to find %APPDATA%\kicad.
There is a “Application data” folder in my user-folder, but no “kicad” file or folder inside.
Just copy paste %APPDATA%\kicad into explorer address window or into windows run dialog (win+r)
Wow. That did the trick. But what the heck is this hidden folder? I already showed all my hidden folders but this thing didn’t appear.
Anyway - it works. Thanks alot @qu1ck! :ok_hand:
%APPDATA% usually expands to C:\Users\<user>\AppData\Roaming. AppData is hidden but it’s nothing special and should be visible when you enable hidden items view.
