Hi I am trying not to fill a zone in the middle. I created 2 zone at least for each layer. But I found some line… Will these affect the production?
I highledted it as BLUE. Thanks!
Why don’t you create the gerbers and check them? I think you have to do that anyways.
The gerber files are all that matters. The 3D view may not be reliable.
What you have in the first picture is the edges of copper zone polygons. They are shown even when that place isn’t filled (because there are tracks there).
What you see in “Seeedstudio” picture is probably a viewer artifact. You have probably drawn two zones so that their edges are exactly in the same y-coordinate. Another option is that there’s a very small gap between the zones which isn’t visible in KiCad and gerbview.
It’s easier to make the zones in the same net overlapping, they will create one copper pour. If you need a non-filled area inside a filled area you can also consider using one big zone and inside it a keepout area and choose to keep only “copper pours” out.
How to do a keep out area?
Ok I think I just found about it. Thanks!
Hey I just learned how to make a keep out zone. Thanks man!
