ebike
March 8, 2021, 6:28am
#1
Hi All,
I was trying to place a 4049 CMOS part in the schematic editor, but the library is not showing. ( Nor for that matter, is the 74xx logic ic’s lib)
I am running Version 5.99.0 on MacOS.
I see all the other libraries but it seems none of the ones starting with a number …
In Finder I go to the “Applications Support/ kicad/ library” folder and they are visible there, but they just refuse to show up in Kicad …
(Actually I see a 4xxx.kicad_sym entry in path above … for the 4xxx series, can’t see any .lib files, has this changed?)
Any idea’s on how to debug this …
Cheers
I do have the 4049 in KiCad-nightly V5.99:
And 74xx:
I have 5 libraries starting with a number listed in: Eeschema / Preferences / Manage Symbol Libraries / Global Libraries
KiCad does not search for libraries, and it only shows & uses libraries listed in the table above. If you add those libraries starting with a number to the library table, can you use them then?
Maybe it’s just a small hickup not worth spending much time on, if more (or all) mac users have this issue then it is a problem in the way KiCad is installed on mac.
(I run Linux myself).
Application: KiCad Schematic Editor
Version: 5.99.0-unknown-56f6e7cc17~117~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-66-generic x86_64, 64 bit, Little endian, wxGTK, mate, x11
Date: Mar 7 2021 08:05:29
Boost: 1.71.0
OCC: 7.3.0
Curl: 7.68.0
ngspice: 31
Compiler: GCC 9.3.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Sidenode: in nightlies the file names should end in kicad_sym not lib as they are already on the new file format. The files that one should have are the ones that are found in this gitlab repo https://gitlab.com/kicad/libraries/kicad-symbols
ebike
March 8, 2021, 7:26pm
#4
Thanks,
I had to manually add those libs with the Library Manager and now works fine. Must be a bug with MacOS that those don’t show up as being available …
Cheers
system
Closed
June 6, 2021, 7:26pm
#5
