Hello, am trying the nightly builds for Linux Mint with the js-reynaud/ppa-kicad ppa. With a new project and trying to open the schematic editor for the first time I get a box that pops up asking to select a symbol library table file. The recommended option is already checked but there is no way to proceed without selecting a library table file. What is the recommended practice here? I know some library management stuff is changing and trying to figure out the recommended course of action here. Thanks!
you need to download the kicad-symbols and kicad-footprints from
after that copy the “sym-lib-table” to /home/$USERNAME/.config/kicad
and the “fp-lib-table” to /home/$USERNAME/.config/kicad/
make sure the ${KICAD_SYMBOL_DIR} and ${KISYSMOD} environmental variables are set to the correct location to where ever you saved the files.
here is a script that might help, if your curious.
https://www.supyrow.com/electronics/kicad5-libraries-repos.shtml
NOTE: this is NOT an official script.
more information here:
thanks su_pyrow, that was it. I copied the sym-lib-table and fp-lib-table from the downloaded libraries and placed them in the .config folder. Then I set the paths in eeschema and pcb new and all was well. THKS!
anytime
Am about to test your script and am wondering about the custom libs and how to set them in the following lines:
head -n -1 $WORKING_TREES/LIBRARIES/kicad-footprints/fp-lib-table > /home/$USERNAME/.config/kicad/fp-lib-table; echo ' (lib (name MyCustomParts)(type KiCad)(uri "$(KISYSMINE)/MyCustomParts.pretty")(options "")(descr "My Custom Component Footprints")))' >> /home/$USERNAME/.config/kicad/fp-lib-table;
head -n -1 $WORKING_TREES/LIBRARIES/kicad-symbols/sym-lib-table > /home/$USERNAME/.config/kicad/sym-lib-table echo ' (lib (name MyCustomComponents)(type Legacy)(uri ${KISYSMINE}/MyCustomLibrary/MyCustomComponents.lib)(options "")(descr "My Custom Schematic Symbols")))' >> /home/$USERNAME/.config/kicad/sym-lib-table;
I assume I edit MyCustomParts and MyCustomComponents to the names of my libs. But I have quite a few custom components libs. How can I add these, because I can add just one?
Thanks.
I got an error at line 380, unexpected newline; echo "" >>
Now it seems that the script you have listed on your webpage is different from the one you can download here:
https://www.supyrow.com/code/data/kicad5-libraries-repos.sh
Which one is right?
Edit: the listed script has date 02-26-2018 and seems the latest.
In case any other Windows users are looking for where these library folders live, I think it’s
\AppData\Roaming\kicad
But it sure seems a lot more difficult to find essential information like this than it should. A couple of sentences in the “Please select a symbol library table file” dialog would have saved me an hour of googling.
