Nightly Build Installation on linux
sudo add-apt-repository ppa:kicad/kicad-dev-nightly
sudo apt update
sudo apt install kicad-nightly
I am trying to install latest kicad nightly build on linux machine, and I am unable to get latest version
Below is the version info shown after installation:
Version: 7.99.0-unknown-a3754785df~172~ubuntu20.04.1, release build
	wxWidgets 3.2.1
	FreeType 2.10.1
	HarfBuzz 2.6.4
	FontConfig 2.13.1
Platform: Ubuntu 20.04.6 LTS, 64 bit, Little endian, wxGTK, ubuntu, x11
	Date: Jun 12 2023 16:03:36
	Boost: 1.71.0
	OCC: 7.5.2
	Curl: 7.68.0
	ngspice: 40
Build Info shows that this was build on Jun 12 2023
Can someone help with installation of latest weekly builds?
I’m having the same issue. Update of the nightly is stuck on the: Date: Jun 12 2023 16:03:36 version. Libraries and 3D models do update when I run system updates, but KiCad itself does not.
paul@cezanne:~$ sudo apt update
Ign:25 http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu focal/main amd64 Packages
Ign:26 http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu focal/main i386 Packages
Err:25 http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu focal/main amd64 Packages
  Cannot initiate the connection to ppa.launchpad.net:80 (2620:2d:4000:1::3e). - connect (101: Network is unreachable) [IP: 185.125.190.52 80]
Err:26 http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu focal/main i386 Packages
W: Failed to fetch http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu/dists/focal/main/binary-amd64/Packages  Cannot initiate the connection to ppa.launchpad.net:80 (2620:2d:4000:1::3e). - connect (101: Network is unreachable) [IP: 185.125.190.52 80]
W: Failed to fetch http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu/dists/focal/main/binary-i386/Packages  Cannot initiate the connection to ppa.launchpad.net:80 (2620:2d:4000:1::3e). - connect (101: Network is unreachable) [IP: 185.125.190.52 80]
W: Some index files failed to download. They have been ignored, or old ones used instead..
And an upgrade shows that footpritns and symbols are updated:
paul@cezanne:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
  kicad-nightly-footprints kicad-nightly-symbols
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 26,3 MB of archives.
After this operation, 293 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu focal/main amd64 kicad-nightly-footprints all 202310232318+4a50e5d33~14~ubuntu20.04.1 [23,8 MB]
Get:2 http://ppa.launchpad.net/kicad/kicad-dev-nightly/ubuntu focal/main amd64 kicad-nightly-symbols all 202310220921+0a27a187~10~ubuntu20.04.1 [2.569 kB]
Fetched 26,3 MB in 22s (1.203 kB/s)
(Reading database ... 495971 files and directories currently installed.)
Preparing to unpack .../kicad-nightly-footprints_202310232318+4a50e5d33~14~ubuntu20.04.1_all.deb ...
Unpacking kicad-nightly-footprints (202310232318+4a50e5d33~14~ubuntu20.04.1) over (202310102017+b64cd3571~14~ubuntu20.04.1) ...
Preparing to unpack .../kicad-nightly-symbols_202310220921+0a27a187~10~ubuntu20.04.1_all.deb ...
Unpacking kicad-nightly-symbols (202310220921+0a27a187~10~ubuntu20.04.1) over (202310111317+ea20e467~10~ubuntu20.04.1) ...
Setting up kicad-nightly-footprints (202310232318+4a50e5d33~14~ubuntu20.04.1) ...
Setting up kicad-nightly-symbols (202310220921+0a27a187~10~ubuntu20.04.1) ...
