Yes, exactly. The idea was that we are not PSPICE, but ngspice. But we want to read PSPICE model files.
However I never thought about adding an .include statement to the text field!
That could be done even before this nice spicey gui was added. When I generated netlists for spice via the netlist button in version 4, it was good to keep the schematic self-contained and completely documented without the need to manually add stuff afterwards to the generated file. One had to be careful to not end up with a very messy schematic, but at least it contained everything needed to be able to pick up the schematic again after 6 months or so.
Today’s solution is much neater, because the model is directly coupled to the part. That is much much better.
I would like to suggest to add a phrase containing the word “only” to section 16.13.5 of the user manual and make the behaviour explicit. Perhaps I am more thinking in terms of a reference manual than a users manual, but I think it might be better to be clear, than it is to leave the matter open to interpretation in a multi language and multicultural environment.
m
On windows 10, I cannot seem to create a file as .spiceinit. It demands a “valid filename”. I looked throughout the ngspice_dll_64.zip and found a global init file called spinit. Should the init file in the C:\users<your name> be spinit or spiceinit without the leading period.
Use the alternative name
spice.rc
A post was merged into an existing topic: How to install a spice app into Eeschema?
Application: kicad
Version: 5.0.0-fee4fd1~66~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.0g zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 4.15.0-30-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 2.24
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.3.0 with C++ ABI 1011
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_WXPYTHON=OFF
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
To get the .spiceinit to be read, I had to put it into /usr/share/kicad on Linux Mint 19 (Ubuntu 18.04). I added the “set ngdebug” line to .spiceinit to be sure that I could tell it was being read. I had followed mifi’s “FOR THE RECORD (on Linux)” above. By the way, before moving the .spiceinit to where it was actually being read, I noticed that KiCAD worked fine with VDMOS models (except that the GUI does not put them in the pulldown menu, as others have noted). It appears that “set ngbehavior=ps” is not required for just reading VDMOS models, only PSPICE? Upgrading KiCAD to NGspice 28 is a major step forward, as I use a lot of VDMOS models (often from LTspice). Thanks to all who have made this possible.
