Hi Mates,
I am new to KiCad and PCB designing.
I got installed the current stable version on a Win7-X64 PC and started working with a Schematic in the getting_started_in_kicad.html.
When I run the ERC check after finishing the schematic, around 6 pin not connected errors came up and I tried wiring them again etc …but not able to find the actual problem causing the error.
Please find the screenshot of the error and the ERC file.
RC report (07/10/16 21:34:39, Encoding UTF8 )
***** Sheet /
ErrType(2): Pin not connected (and no connect symbol found on this pin)
@ (139.70 mm,92.71 mm): Pin 6 (Bidirectional) of component IC1 is unconnected.
@ (149.86 mm,127.00 mm): Pin 1 (Passive) of component R4 is unconnected.
@ (142.24 mm,127.00 mm): Pin 2 (Passive) of component R4 is unconnected.
@ (116.84 mm,124.46 mm): Pin 1 (Passive) of component J1 is unconnected.
@ (116.84 mm,127.00 mm): Pin 2 (Passive) of component J1 is unconnected.
@ (116.84 mm,129.54 mm): Pin 3 (Passive) of component J1 is unconnected.
** ERC messages: 6 Errors 0 Warnings 6
