When I lay a trace down sometimes I make a 90 bend. I would like to edit that trace to be a 45 but I can’t
seem to edit it. I have tried to use the “break trace” command but it does not appear to break it and if I try
to move the corner it moves the entire trace top to bottom. Can anyone tell me how they would edit the
trace or do you just rip it up and relay it out? I wanted to include an image but do not look like I can do that.
info - Version:5.1.3-ffb9f22-84-ubuntu18.04.1, release build
Platform:Linux 4.15.0-55-generic x86_64,64 bit
The “D” key will drag at a 45. Right click once a trace is selected to see options. I thought there used to be a setting to make this default but I can’t seem to find it at the moment.
The routing seems to get better with every new version; so it make sense to use the newest version.
In the Interactive Router settings, ensure that “Remove Redundant Tracks” is selected. Then draw a new line from track to track that will end up being 45 degrees; this should make the other tracks automatically delete.
