New User - KiCAD always crashes on old MacBook
I’m trying to move from Eagle 9.6.2 to KiCAD 7.0.11 on my MACBook Pro (mid 2012), with Intel Core i7, running Catalina 10.15.7, I installed KiCAD using MacPorts and that seemed to work although it took hours. The terminal log during installation doesn’t show any errors, exceptions, or failures.
I can only get this far: I have a folder with name.sch, name.brd, name.kicad_pro, and when I tried the PCB editor, ~name.brd.lck was made.
Everytime I try to either edit the schematic or PCB, KiCAD crashes as soon as I lift the button on my mouse.
I’m open for ideas. I am hoping I don’t need a new computer once I found MacPorts.
Thanks!
.sch and .brd are Eagle file suffixes. They need to be imported into KiCad, not edited right away.
Star a new KiCad native project to get familiar with it.
Sorry I left out details and thank you for the prompt comment. In KiCAD, I imported a non-KiCAD project (the EAGLE files, as you noted) into an empty folder. KiCad sees the files and show the hierarchy name.kicad_pro with name.brd and name.sch in the project. I thought there should be a dialogue as KiCAD maps the layers, but if I try anything, it crashes. I’ve been using this as my guide: https://community.element14.com/technologies/open-source-hardware/b/blog/posts/working-with-kicad-7-importing-eagle-files
KiCad has its own docs. Try here:
https://docs.kicad.org/7.0/en/kicad/kicad.html#importing_a_project_from_another_eda_tool
Thanks! I’ll look at this soon!
Here is what KiCad | 7.0 | English | Documentation | KiCad says wrt importing projects from another EDA tool:
To import a project from one of these tools, choose the appropriate option from the ‘Import Non-KiCad Project’ submenu of the ‘File’ menu. (I did)
You will be prompted to select either a schematic or a board file in the import file browser dialog. (There was no prompt, I tried both. My files do have the same name, that’s native to EAGLE)
Once the requested files are selected, you will be asked to select a directory to store the resulting KiCad project. (KiCad asked, and wrote the files in the selected directory)
That’s as far as the KiCad docs goes, the Element14 link illustrated the mapping of layers, but the mapping didn’t occur. It seems to stall/break about then. Still open for any and all ideas.
In any case, the import should generate .kicad_sch and .kicad_pcb files. It’s those generated files that you should be editing. If you haven’t got those files, then the import hasn’t worked.
I never had Eagle so hopefully someone else can help you.
Thank you - it looks like the import hasn’t worked. I’m going to see if I can borrow a current MacBook and see if it’s a platform issue.
So it generated the files, but you think the import hasn’t worked? Have you opened the generated project in the directory they were saved in?
It copied the Eagle .sch and .brd files but didn’t generate the KiCad equivalent. Is there a way I can post a screenshot or jpg?
Increase your level by reading some posts:
https://forum.kicad.info/t/new-member-information/38391/2
How hard is it to swap out the hard drive? You might get it to run under Linux? I’m not sure what processor the MacBook uses or if Linux is an option.
I’ve changed to an 1TB SSD hard drive and doubled the memory to 16GB about 6 years ago, never had an issue. It’s running a 2.9GHz Dual-Core Intel i7 dual core. This is the only app I’ve had problems yet, but it is 13 years old(!).
This is what I have in my KiCad directory, it’s just not converting the EAGLE files to .kicad_sch and .kicad_pcb
Screen Shot 2025-07-20 at 1.19.38 PM
Later today I’m going to make a new Project using only KiCad, I hope that will tell me if my install of KiCad is valid.
Thanks, everyone.
OK, my install doesn’t work. I create a new Project in KiCad, the new directory shows the expected file structure and crashes if I try to do anything. I’ll borrow a current MacBook and see if it’s my machine.
Screen Shot 2025-07-20 at 1.35.25 PM
Do you get a macOS crash report with any details?
Yes, all above my understanding. I’m not allowed to post attachments yet. It’s a 28 page report, and all I know how to do is convert the *.pdf pages to 28 *.jpgs, but I have a 5 image upload maximum. Even if I view the Word document that I copied the crash report into - in web layout (one continuous page), it still makes 28 pages of *.pdf. Let me see if I can merge *.pdf pages to make fewer *.jpgs.
Can you copy the text and insert it inside a blockquote?
1st 5 *.jpgs of crash report, 4 more postings to follow.
Now it says I can only attach 1 image. I’ll try something else later. Grr-r-r.
1st block quote, I have more than 32K characters:
Process:               kicad [55917]
Path:                  /Applications/MacPorts/*/kicad.app/Contents/MacOS/kicad
Identifier:            org.kicad.kicad
Version:               7.0.11 (7.0.11)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           kicad [55917]
User ID:               501
Date/Time:             2025-07-20 13:38:28.529 -0400
OS Version:            Mac OS X 10.15.7 (19H2026)
Report Version:        12
Anonymous UUID:        84963472-15C5-A3A4-D53B-30C95A7C3211
Time Awake Since Boot: 170000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [55917]
VM Regions Near 0:
    __TEXT                 0000000101d82000-0000000102496000 [ 7248K] r-x/r-x SM=COW  /opt/local/bin/kicad
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   org.kicad.kicad               	0x0000000101f2c98b KIWAY::Player(FRAME_T, bool, wxTopLevelWindow*) + 219
1   org.kicad.kicad               	0x0000000101dd10ac KICAD_MANAGER_CONTROL::ShowPlayer(TOOL_EVENT const&) + 428
2   org.kicad.kicad               	0x0000000101fc4941 COROUTINE<int, TOOL_EVENT const&>::callerStub(long) + 49
Thread 1:
0   libsystem_pthread.dylib       	0x00007fff701f7b68 start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:: com.apple.NSEventThread
0   libsystem_kernel.dylib        	0x00007fff70134dea mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff70135160 mach_msg + 60
2   com.apple.CoreFoundation      	0x00007fff36ebfd07 __CFRunLoopServiceMachPort + 247
3   com.apple.CoreFoundation      	0x00007fff36ebe7c1 __CFRunLoopRun + 1329
4   com.apple.CoreFoundation      	0x00007fff36ebdc33 CFRunLoopRunSpecific + 466
5   com.apple.AppKit              	0x00007fff34315bf4 _NSEventThread + 132
6   libsystem_pthread.dylib       	0x00007fff701fc109 _pthread_start + 148
7   libsystem_pthread.dylib       	0x00007fff701f7b8b thread_start + 15
Thread 6:: com.apple.CFSocket.private
0   libsystem_kernel.dylib        	0x00007fff7013d0ee __select + 10
1   com.apple.CoreFoundation      	0x00007fff36ee8bab __CFSocketManager + 633
2   libsystem_pthread.dylib       	0x00007fff701fc109 _pthread_start + 148
3   libsystem_pthread.dylib       	0x00007fff701f7b8b thread_start + 15
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x00000000fffffffd  rcx: 0x0000000000000000  rdx: 0x00000000000ae0b0
  rdi: 0x0000000000000020  rsi: 0x00007f99ed500000  rbp: 0x00007f99f0b8bd10  rsp: 0x00007f99f0b8bb90
   r8: 0x0000000000000002   r9: 0x000000000000001f  r10: 0x00007f99ed500000  r11: 0x00007f99ed509360
  r12: 0x0000000000000001  r13: 0x0000000000000000  r14: 0x0000000000000000  r15: 0x0000000102558200
  rip: 0x0000000101f2c98b  rfl: 0x0000000000010202  cr2: 0x0000000000000000
Logical CPU:     1
Error Code:      0x00000004 (no mapping for user data read)
Trap Number:     14
Binary Images:
       0x101d82000 -        0x102495f53 +org.kicad.kicad (7.0.11 - 7.0.11) <357DF9C9-BC9A-3150-9191-80F8D2AD7D40> /Applications/MacPorts/*/kicad.app/Contents/MacOS/kicad
       0x1026eb000 -        0x1026ebfff +libMacportsLegacySupport.dylib (0) <AF824A55-D4A8-36C1-AFD6-692B2DDB9906> /opt/local/lib/libMacportsLegacySupport.dylib
       0x1026f4000 -        0x1026ffff3 +libwx_osx_cocoau_gl-3.2.0.3.0.dylib (0) <3E16EDEA-2717-38A8-A3E3-CBD52E0ED54A> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_osx_cocoau_gl-3.2.0.3.0.dylib
       0x102714000 -        0x102773ff3 +libwx_osx_cocoau_aui-3.2.0.3.0.dylib (0) <7AB3A0DE-D861-3A5D-A3CE-10D42493D02E> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_osx_cocoau_aui-3.2.0.3.0.dylib
       0x1027b7000 -        0x102829ff3 +libwx_osx_cocoau_html-3.2.0.3.0.dylib (0) <13EDBB55-1A36-38E0-ACDB-E95D84D6D5A8> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_osx_cocoau_html-3.2.0.3.0.dylib
       0x10287f000 -        0x102da6fff +libwx_osx_cocoau_core-3.2.0.3.0.dylib (0) <B7519CF5-7676-3536-B3D6-36FC2CED969A> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_osx_cocoau_core-3.2.0.3.0.dylib
       0x10307b000 -        0x1030b5fff +libwx_baseu_net-3.2.0.3.0.dylib (0) <17EB23B5-0937-3F79-AB7B-64FD79F8909F> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_baseu_net-3.2.0.3.0.dylib
       0x1030d8000 -        0x1032a3ff3 +libwx_baseu-3.2.0.3.0.dylib (0) <9AD40037-169A-3502-AC1B-A174900343CF> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_baseu-3.2.0.3.0.dylib
       0x103350000 -        0x1033d4ffb +libwx_osx_cocoau_propgrid-3.2.0.3.0.dylib (0) <A41E84F4-1BE7-3773-B307-C1EC07BC3287> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_osx_cocoau_propgrid-3.2.0.3.0.dylib
       0x10343e000 -        0x10344bfff +libwx_baseu_xml-3.2.0.3.0.dylib (0) <EF97E40B-7F46-3FC1-A39F-625B349509D3> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_baseu_xml-3.2.0.3.0.dylib
       0x103458000 -        0x103619fff +libwx_osx_cocoau_stc-3.2.0.3.0.dylib (0) <C6EB238B-B2D2-3F7B-AFBF-CD2323897756> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_osx_cocoau_stc-3.2.0.3.0.dylib
       0x10368a000 -        0x1037c5ff3 +libwx_osx_cocoau_richtext-3.2.0.3.0.dylib (0) <825DA004-622F-3043-A123-1FB8B2F8C100> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/lib/libwx_osx_cocoau_richtext-3.2.0.3.0.dylib
       0x103858000 -        0x1038a5ff3 +libodbc.2.dylib (0) <9AAA9E01-00B4-3EF4-A1AD-EBFA7D354062> /opt/local/lib/libodbc.2.dylib
       0x1038ba000 -        0x103943fff +libcurl.4.dylib (0) <630F5043-56D9-3B53-870A-316BBC711154> /opt/local/lib/libcurl.4.dylib
       0x103962000 -        0x10399afff +libGLEW.2.2.0.dylib (0) <539F4358-D338-34EB-8C8D-871E565A0284> /opt/local/lib/libGLEW.2.2.0.dylib
       0x1039e1000 -        0x103aa7ffb +libcairo.2.dylib (0) <0DA3C68C-A427-36C5-9DFB-37DED33BDF1D> /opt/local/lib/libcairo.2.dylib
       0x103ae7000 -        0x103b55ff3 +libpixman-1.0.dylib (0) <0DD1EAD9-8BA2-3E49-B30C-A41DC3C5D130> /opt/local/lib/libpixman-1.0.dylib
       0x103b87000 -        0x103c12ff7 +libfreetype.6.dylib (0) <C1AF8283-F442-37CE-926C-E81BD5731DBD> /opt/local/lib/libfreetype.6.dylib
       0x103c30000 -        0x103cfbffb +libharfbuzz.0.dylib (0) <3D289923-2D5F-35E3-A9AC-362EDA9C4EE8> /opt/local/lib/libharfbuzz.0.dylib
       0x103ded000 -        0x103e21ffb +libfontconfig.1.dylib (0) <E7CA80E1-F30D-39C5-B085-BD52D737E019> /opt/local/lib/libfontconfig.1.dylib
       0x103e2f000 -        0x104194ff7 +org.python.python (3.11.13, [c] 2001-2023 Python Software Foundation. - 3.11.13) <EA70217D-EFD2-3545-8A47-9E0C1F9BA83E> /opt/local/Library/Frameworks/Python.framework/Versions/3.11/Python
       0x1044c4000 -        0x104518ffb +libc++.1.0.dylib (0) <413DF086-E161-3924-A0EC-DD4D1AE05495> /opt/local/lib/*/libc++.1.0.dylib
       0x10456f000 -        0x104574fff +libltdl.7.dylib (0) <019B64E9-FBB6-3A00-A589-D641448CBE0F> /opt/local/lib/libltdl.7.dylib
       0x104581000 -        0x104681ffb +libiconv.2.dylib (0) <D6D77891-C450-39DB-A41A-5E92B58E9B38> /opt/local/lib/libiconv.2.dylib
       0x104699000 -        0x1046b4ff3 +libnghttp2.14.dylib (0) <A4AB9898-153C-3FD3-9E92-5FD3EE295A85> /opt/local/lib/libnghttp2.14.dylib
       0x1046c8000 -        0x1046f6ff7 +libidn2.0.dylib (0) <3A63B76C-AC89-3F9B-BCEB-74E6ECBB0D57> /opt/local/lib/libidn2.0.dylib
       0x1046fe000 -        0x10470effb +libpsl.5.dylib (0) <028164D6-4A06-3833-A178-1BE89CD7E529> /opt/local/lib/libpsl.5.dylib
       0x104712000 -        0x1047acff7 +libssl.3.dylib (0) <C16BE3E3-8FE9-3E18-B674-AD7CA8582B38> /opt/local/libexec/*/libssl.3.dylib
       0x1047f1000 -        0x104b38fe3 +libcrypto.3.dylib (0) <DE6D090C-2A95-30CC-A51C-FCB5C4EC0DCB> /opt/local/libexec/*/libcrypto.3.dylib
       0x104cbe000 -        0x104d6bfff +libzstd.1.dylib (0) <DC7F5ADE-8374-3E79-9E2A-A017E6E2AAAC> /opt/local/lib/libzstd.1.dylib
       0x104d80000 -        0x104d89ff7 +libbrotlidec.1.dylib (0) <01BC84EE-4129-3971-A2FE-FEA21C8D1C68> /opt/local/lib/libbrotlidec.1.dylib
       0x104d93000 -        0x104da3fff +libz.1.dylib (0) <CB379833-E1C1-391F-9BAC-D907687F7896> /opt/local/lib/libz.1.dylib
       0x104dad000 -        0x104f6eff3 +libunistring.5.dylib (0) <CCDA641A-3BFB-30EE-A7C0-C2A5FE2AD187> /opt/local/lib/libunistring.5.dylib
       0x104f89000 -        0x104f9affb +libintl.8.dylib (0) <1D5AB3B5-3FDC-3839-B8F3-8BFE784CF791> /opt/local/lib/libintl.8.dylib
       0x104fa1000 -        0x104fc0ff7 +libbrotlicommon.1.dylib (0) <29E966FA-2700-34CB-BDCC-CA2AC5E1BC2C> /opt/local/lib/libbrotlicommon.1.dylib
       0x104fca000 -        0x104febffb +libpng16.16.dylib (0) <14DB5B86-3738-3568-9C60-A1E990949BC4> /opt/local/lib/libpng16.16.dylib
       0x104ff5000 -        0x104ff5fff +libX11-xcb.1.dylib (0) <3C5FCD8F-C3B1-3007-BF49-5DAFE1095572> /opt/local/lib/libX11-xcb.1.dylib
       0x104ff9000 -        0x10500cffb +libxcb.1.dylib (0) <FEADBFB3-30E2-304A-856F-2415D999A2DA> /opt/local/lib/libxcb.1.dylib
       0x105023000 -        0x105028fff +libxcb-render.0.dylib (0) <19E2BBE5-3B2C-3A7B-AC3A-27811686E8F6> /opt/local/lib/libxcb-render.0.dylib
       0x105031000 -        0x105037fff +libXrender.1.dylib (0) <6627CE52-39D6-3772-86F7-D8DA8A5D2504> /opt/local/lib/libXrender.1.dylib
       0x105043000 -        0x105132ff3 +libX11.6.dylib (0) <BCBD768D-B1C7-3DA0-881C-599EB32C1AC6> /opt/local/lib/libX11.6.dylib
       0x10515d000 -        0x105167ff7 +libXext.6.dylib (0) <8CC08001-0FA1-32B4-8EDF-173EEC28AEC5> /opt/local/lib/libXext.6.dylib
       0x105173000 -        0x10518eff7 +libexpat.1.dylib (0) <4772C3C8-FE23-3C37-9B80-D3AB2848E518> /opt/local/lib/libexpat.1.dylib
       0x10519e000 -        0x1051adff3 +libbz2.1.0.dylib (0) <51D64A7C-E68A-313C-8AA2-5D175A1FCBBD> /opt/local/lib/libbz2.1.0.dylib
       0x1051b9000 -        0x1051bafff +libXau.6.dylib (0) <E4735FA7-DE00-3EF4-98BE-B61C0DC821EB> /opt/local/lib/libXau.6.dylib
       0x1051bf000 -        0x1051c2fff +libXdmcp.6.dylib (0) <CDCACE90-E509-3F2D-905C-A707F96FC6C3> /opt/local/lib/libXdmcp.6.dylib
       0x1051cb000 -        0x1052b6ff7 +libglib-2.0.0.dylib (0) <363921BE-5DD1-38D1-BCF4-52D09DCE851D> /opt/local/lib/libglib-2.0.0.dylib
       0x10531b000 -        0x105330ff7 +libgraphite2.3.dylib (0) <CC1CC48C-FF0D-3FF4-AF7F-3D82320B4084> /opt/local/lib/libgraphite2.3.dylib
       0x10533d000 -        0x1053cdff3 +libpcre2-8.0.dylib (0) <8F265251-91AC-3960-8542-90122EFE5231> /opt/local/lib/libpcre2-8.0.dylib
       0x1053db000 -        0x1053f3ff7 +libc++abi.1.0.dylib (0) <54E4B851-0E7D-3953-AE97-4E9FF886FCC5> /opt/local/lib/*/libc++abi.1.0.dylib
       0x10674d000 -        0x1067df267  dyld (750.7) <9F48F7F8-94D0-3793-99B7-DDEF657EF956> /usr/lib/dyld
       0x109398000 -        0x10939b047  libobjc-trampolines.dylib (787.1) <571C6A14-9E0E-3139-B82D-A1A3D46F2C9C> /usr/lib/libobjc-trampolines.dylib
    0x7fff2cd3d000 -     0x7fff2cdbbff6  com.apple.driver.AppleIntelHD4000GraphicsMTLDriver (14.7.28 - 14.0.7) <0AEC62B0-4951-3F9C-8A6A-FC451962F01D> /System/Library/Extensions/AppleIntelHD4000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsMTLDriver
    0x7fff326b5000 -     0x7fff326b9ffb  com.apple.agl (3.3.3 - AGL-3.3.3) <D5670F33-361F-3971-9382-290BB12EA788> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fff32aa2000 -     0x7fff32aa2fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <C1FB2338-2D52-3884-BED3-071A82B1FD77> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff32aa3000 -     0x7fff32abaff7  libCGInterfaces.dylib (524.2.1) <69118118-1CEC-3019-A36E-3EC2FF1CAD8F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff32abb000 -     0x7fff33356fcf  com.apple.vImage (8.1 - 524.2.1) <4B6AB2C1-7CF5-3FDA-AC1C-04E531AB9BCE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff33357000 -     0x7fff334ecfef  libBLAS.dylib (1303.60.1) <C157903D-417A-322B-916E-DDCFE2AF97EE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff334ed000 -     0x7fff3382efff  libBNNS.dylib (144.100.2) <69FA0C4F-B59D-374A-9DCF-E9FA79F332FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff3382f000 -     0x7fff33bd6fff  libLAPACK.dylib (1303.60.1) <6FEC8434-0C35-3528-A3DE-E3C78A748B6C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff33bd7000 -     0x7fff33becffc  libLinearAlgebra.dylib (1303.60.1) <AAC1A8DA-0B44-3D52-A03F-1DFED19D33BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff33bed000 -     0x7fff33bf2ff3  libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff33bf3000 -     0x7fff33c63fff  libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff33c64000 -     0x7fff33c76ff7  libSparseBLAS.dylib (1303.60.1) <CFFEAA75-99FB-369E-80A1-4BC73ADEBEA9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff33c77000 -     0x7fff33e09fe3  libvDSP.dylib (735.140.1) <1586D162-55FD-3EC0-AFC7-975EAE2D0DD6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff33e0a000 -     0x7fff33f88fe7  libvMisc.dylib (735.140.1) <61CF1106-41C2-3971-9187-BD1D53C00343> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff33f89000 -     0x7fff33f89fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <4686AE53-FD05-302C-AC20-C014EFC2305F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff33f8a000 -     0x7fff33fe9ff0  com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff34133000 -     0x7fff34ef1ffb  com.apple.AppKit (6.9 - 1894.70.110) <058D0F31-D353-36D9-83CD-1709EBB1390E> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff34f41000 -     0x7fff34f41fff  com.apple.ApplicationServices (48 - 50) <A74C5919-EA2A-30FB-917E-09AAB26E96B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff34f42000 -     0x7fff34fadfff  com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff35046000 -     0x7fff35084ff0  libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff350df000 -     0x7fff3510efff  com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff3510f000 -     0x7fff35113ffb  com.apple.ColorSyncLegacy (4.13.0 - 1) <4E0574BC-921B-33D4-916B-2DD60D141BF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff351ad000 -     0x7fff35204ffa  com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff35205000 -     0x7fff35213fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff35214000 -     0x7fff35259ffa  com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff3525a000 -     0x7fff35264ff7  com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff35265000 -     0x7fff35272ffc  com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff35273000 -     0x7fff35354ff2  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <43014BB0-6604-3513-AB52-8D8577204FA6> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff35356000 -     0x7fff35356fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <2FAE7F8D-2358-3B10-B47E-27B90B368557> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff356ed000 -     0x7fff35a7bffa  com.apple.CFNetwork (1128.1 - 1128.1) <04F37E21-8AC6-35BF-8D2C-8ED954B09026> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff35af7000 -     0x7fff35af7fff  com.apple.Carbon (160 - 162) <0C07A0EC-9474-3A5E-82A0-FD98B7C83BD8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff35af8000 -     0x7fff35afbff3  com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff35afc000 -     0x7fff35df0ff3  com.apple.HIToolbox (2.1.1 - 994.7) <1869947E-482B-30F2-A8A9-B8F78CA69F6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff35df1000 -     0x7fff35df4ff3  com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff35df5000 -     0x7fff35dfaff7  com.apple.ImageCapture (9.0 - 1600.65.1) <19E8B178-4C4D-3779-8815-E905310F20EF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff35dfb000 -     0x7fff35dfbfff  com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff35dfc000 -     0x7fff35e16ffa  com.apple.openscripting (1.7 - 185.2) <C0F2228C-9B4D-3976-AE4F-56608176A9C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff35e37000 -     0x7fff35e37fff  com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff35e38000 -     0x7fff35e3aff7  com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff35e3b000 -     0x7fff35e41fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff35fdb000 -     0x7fff35fdbfff  com.apple.Cocoa (6.11 - 23) <9C7AC07A-7C05-37D4-910C-E9CDB239AFA8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff35fe9000 -     0x7fff360dffff  com.apple.ColorSync (4.13.0 - 3394.15) <97F94272-0DB2-307F-A2B6-4FEC74DB37A6> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff363ca000 -     0x7fff368d3ffb  com.apple.audio.CoreAudio (5.0 - 5.0) <47923B12-3D14-328A-9C86-27A3A2A73068> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff368d4000 -     0x7fff3690cfff  com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff3690d000 -     0x7fff36d08ff8  com.apple.CoreData (120 - 977.3) <CEAA4BC1-62AB-3702-B790-82A55EA10302> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff36d09000 -     0x7fff36e3bff6  com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff36e3c000 -     0x7fff372bcff9  com.apple.CoreFoundation (6.9 - 1678.104) <CA9600EB-C7BE-38C4-968D-4BF90B1C9550> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff372be000 -     0x7fff37956ff0  com.apple.CoreGraphics (2.0 - 1355.24) <9B167C47-1FDB-3D44-93D0-64CC7B30AB2A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff37964000 -     0x7fff37cbfff0  com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff38081000 -     0x7fff3815cffc  com.apple.CoreMedia (1.0 - 2625.9.4.1) <516C5604-EDE4-3F50-BCE7-234BB99610E0> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff38249000 -     0x7fff38249fff  com.apple.CoreServices (1069.28 - 1069.28) <45131B9C-99AA-340E-947F-E53F2C829F20> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff3824a000 -     0x7fff382cffff  com.apple.AE (838.1 - 838.1) <450501B5-0161-38D0-8986-90718DC3CAE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff382d0000 -     0x7fff385b1ff7  com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff385b2000 -     0x7fff385ffffd  com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff38600000 -     0x7fff38608ff7  com.apple.CoreServices.FSEvents (1268.100.2 - 1268.100.2) <D9B9A080-C59D-3A0D-BC7B-A67137C317C4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff38609000 -     0x7fff38844ff8  com.apple.LaunchServices (1069.28 - 1069.28) <07C85310-A894-344D-8181-CC1E68CA0C82> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff38845000 -     0x7fff388ddff1  com.apple.Metadata (10.7.0 - 2076.7.2) <BB387ED8-F398-3016-B5FC-49202BDD182C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff388de000 -     0x7fff3890bfff  com.apple.CoreServices.OSServices (1069.28 - 1069.28) <704B2084-2AF5-342E-A554-C0DE93229A3F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff3890c000 -     0x7fff38973fff  com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff38974000 -     0x7fff38998ff5  com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff38cbd000 -     0x7fff38e75ffc  com.apple.CoreText (643.1.5.8 - 643.1.5.8) <C6CBD65A-B081-3F0F-A5EE-2AEA10498FA4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff38e76000 -     0x7fff38ebafff  com.apple.CoreVideo (1.8 - 0.0) <D35529AE-8740-320B-BB12-D1E60FDAB06B> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff38ebb000 -     0x7fff38f48ffc  com.apple.framework.CoreWLAN (13.0 - 1601.2) <CCF3BB09-A571-3589-917B-D646A4BDD7CC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff391df000 -     0x7fff391e5fff  com.apple.DiskArbitration (2.7 - 2.7) <C5272B1C-C2D1-3A64-8116-3AC6FAB9E18B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff393da000 -     0x7fff39509ff6  com.apple.FileProvider (304.141.2 - 304.141.2) <D0854CAD-19E0-39CB-A5A4-A3C4F2ED369A> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff39521000 -     0x7fff398e6ff7  com.apple.Foundation (6.9 - 1678.104) <69B915AD-CE6F-3958-8E3A-9D6050989AC2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff39953000 -     0x7fff399a3fff  com.apple.GSS (4.0 - 2.0) <993DB520-C98D-35BB-844D-562EC1A24514> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff39ae0000 -     0x7fff39bf4ff3  com.apple.Bluetooth (7.0.6 - 7.0.6f8) <E7634AA3-92E9-3E8A-80BA-0716B3E05C78> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff39c5a000 -     0x7fff39cfeff3  com.apple.framework.IOKit (2.0.2 - 1726.148.1) <0A9D244C-AECC-3D29-86DE-4F3B04F8DD25> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff39d00000 -     0x7fff39d11ffb  com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff39d90000 -     0x7fff39ef0ff6  com.apple.ImageIO.framework (3.3.0 - 1976.14.1) <8C43C897-A78F-339F-8B7C-1DC3F861349D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff39ef1000 -     0x7fff39ef4fff  libGIF.dylib (1976.14.1) <6DAA6146-4508-3883-AF1A-7CF4B06B1D7D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff39ef5000 -     0x7fff39faeff7  libJP2.dylib (1976.14.1) <A324445F-79FF-38CE-8DBD-BD8749D045D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff39faf000 -     0x7fff39fd3ff7  libJPEG.dylib (1976.14.1) <A5037397-1DF9-3E34-AB1E-41ABF2AC7F55> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff3a251000 -     0x7fff3a26bff7  libPng.dylib (1976.14.1) <B569035E-0E07-39D7-91AC-145618184EC9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff3a26c000 -     0x7fff3a26dfff  libRadiance.dylib (1976.14.1) <91EA6BBB-0797-3688-9C78-5F38FD04FE06> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff3a26e000 -     0x7fff3a2b4ff7  libTIFF.dylib (1976.14.1) <56CE66AC-2701-35CE-9891-3244F3B07FBA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff3a75f000 -     0x7fff3b7fffe1  com.apple.JavaScriptCore (15609 - 15609.4.1.1.1) <5CAFF570-DC41-32A9-9CFB-28210A9B8367> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff3b816000 -     0x7fff3b828ff3  com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff3b829000 -     0x7fff3b829fff  libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff3bbbb000 -     0x7fff3bbc5ffb  com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff3c3e0000 -     0x7fff3c4aafff  com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff3c4c7000 -     0x7fff3c504ff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA>
2nd part of crash report:
Click to show/hide
/System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
   0x7fff3c505000 -     0x7fff3c58ffe2  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
   0x7fff3c590000 -     0x7fff3c5b5ff4  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
   0x7fff3c5b6000 -     0x7fff3c5cbffb  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
   0x7fff3c5cc000 -     0x7fff3c72affc  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
   0x7fff3c72b000 -     0x7fff3c77aff4  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
   0x7fff3c77b000 -     0x7fff3c77cff5  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
   0x7fff3d63b000 -     0x7fff3d647ffe  com.apple.NetFS (6.0 - 4.0) <57CABC68-0585-3989-9161-157DBB544B82> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
   0x7fff3d648000 -     0x7fff3d79fff3  com.apple.Network (1.0 - 1) <7F64A643-A7D5-3089-AF96-78AAF943C1D3> /System/Library/Frameworks/Network.framework/Versions/A/Network
   0x7fff401d1000 -     0x7fff40229fff  com.apple.opencl (3.5 - 3.5) <405873C3-6C6E-307B-9813-8741E1CABD95> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
   0x7fff4022a000 -     0x7fff40246fff  com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
   0x7fff40247000 -     0x7fff40252ffd  com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
   0x7fff40bb8000 -     0x7fff40bbafff  libCVMSPluginSupport.dylib (17.10.22) <4DFF84FA-1F0C-3283-8F56-512344B725CE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
   0x7fff40bbb000 -     0x7fff40bc0fff  libCoreFSCache.dylib (176.21) <627E34BF-5E91-3D07-945B-1B9F3432BFB3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
   0x7fff40bc1000 -     0x7fff40bc5fff  libCoreVMClient.dylib (176.21) <8A019B96-5D30-3140-B3D3-B6225E484BFD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
   0x7fff40bc6000 -     0x7fff40bceff7  libGFXShared.dylib (17.10.22) <7D2BF684-33B2-32F5-A070-EA0AC692D10D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
   0x7fff40bcf000 -     0x7fff40bd9fff  libGL.dylib (17.10.22) <D782B7B9-CD02-35CC-833D-00A76DC28D2D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
   0x7fff40bda000 -     0x7fff40c0eff7  libGLImage.dylib (17.10.22) <F9E0AB2E-3123-361B-BB43-30111B03395B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
   0x7fff40da4000 -     0x7fff40de0fff  libGLU.dylib (17.10.22) <E5027491-0309-3E86-8435-1A1D0DA6C86F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
   0x7fff4181c000 -     0x7fff4182bff7  com.apple.opengl (17.10.22 - 17.10.22) <BCC1E523-1843-3FF8-8F7D-29DA67756434> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
   0x7fff427e9000 -     0x7fff42a6cffb  com.apple.QuartzCore (1.11 - 841.6) <DCD6050B-DB0E-3469-B18B-3DF3FAE77DEC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
   0x7fff435f0000 -     0x7fff4393bff9  com.apple.security (7.0 - 59306.140.11) <3B46FC31-708A-3526-B888-BB7C1A9FBD98> /System/Library/Frameworks/Security.framework/Versions/A/Security
   0x7fff4393c000 -     0x7fff439c4ffb  com.apple.securityfoundation (6.0 - 55236.60.1) <954B6238-07CB-3357-BC4F-AE827DD3F9E3> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
   0x7fff439c5000 -     0x7fff439f2ff7  com.apple.securityinterface (10.0 - 55139.120.1) <D25421B0-F6F6-34DA-BA33-258447A972C9> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
   0x7fff439f3000 -     0x7fff439f7ff8  com.apple.xpc.ServiceManagement (1.0 - 1) <055976F5-69DF-3846-B7CC-D72FA09D1A98> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
   0x7fff446a3000 -     0x7fff4471dff7  com.apple.SystemConfiguration (1.19 - 1.19) <D3494EFE-F392-379E-B21C-0F1B094ECE77> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
   0x7fff4499d000 -     0x7fff44d20ff4  com.apple.VideoToolbox (1.0 - 2625.9.4.1) <65ABE2CC-8180-397A-B783-EC7449871985> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
   0x7fff44fc2000 -     0x7fff4575ffe7  libwebrtc.dylib (7609.4.1.1.1) <C7174FA6-6A0C-3F13-9A64-C262A6655A5D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
   0x7fff45760000 -     0x7fff479caffb  com.apple.WebCore (15609 - 15609.4.1.1.1) <75D5D854-2A87-3C42-A5A4-A7CA11A56B5C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
   0x7fff479cb000 -     0x7fff47bd7ffb  com.apple.WebKitLegacy (15609 - 15609.4.1.1.1) <4F71E2AC-239D-322C-8CF9-AA74CA16341A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
   0x7fff47bd8000 -     0x7fff482ddffd  com.apple.WebKit (15609 - 15609.4.1.1.1) <898C11F5-0EB7-3CF3-840A-F2168D1B0805> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
   0x7fff4868d000 -     0x7fff48752fe7  com.apple.APFS (1412.141.3 - 1412.141.3) <E1179E8D-56DC-3F20-9C5E-B960D608F053> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
   0x7fff48d9e000 -     0x7fff48da9ffc  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <34D2C8C5-0BBC-39CA-B37C-B053A9C327EF> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
   0x7fff49867000 -     0x7fff49868ff1  com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
   0x7fff49c7f000 -     0x7fff49c9cff4  com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
   0x7fff49cf1000 -     0x7fff49cffff7  com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
   0x7fff4a17b000 -     0x7fff4a19fffb  com.apple.framework.Apple80211 (13.0 - 1610.1) <33B50F2F-88CD-3B02-B72E-1E1B916A7FC9> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
   0x7fff4a45d000 -     0x7fff4a46cfd7  com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
   0x7fff4a56b000 -     0x7fff4a576ff7  com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
   0x7fff4a5b8000 -     0x7fff4a600ff7  com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
   0x7fff4a9ef000 -     0x7fff4aa11fff  com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
   0x7fff4aad1000 -     0x7fff4aad4fff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
   0x7fff4aad5000 -     0x7fff4ab25ff7  com.apple.AppleVAFramework (6.1.2 - 6.1.2) <5BBCA7FB-5435-30CA-862F-D82437C383C2> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
   0x7fff4ab6e000 -     0x7fff4ab7dff9  com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
   0x7fff4b711000 -     0x7fff4b952ff8  com.apple.audio.AudioToolboxCore (1.0 - 1104.104) <AB379BF7-A824-3F9C-BF26-BC3BE44A575F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
   0x7fff4b956000 -     0x7fff4ba72fff  com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
   0x7fff4bc2f000 -     0x7fff4bc38ff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
   0x7fff4bc39000 -     0x7fff4bcdaff5  com.apple.backup.framework (1.11.8 - 1298.8.1) <196068B7-B3E8-3CC5-8875-9121190AD954> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
   0x7fff4bcdb000 -     0x7fff4bd67ff6  com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
   0x7fff4be69000 -     0x7fff4bea5ff7  com.apple.bom (14.0 - 219.3) <CE0B1297-4B57-3D61-9B7A-1C945742A4CE> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
   0x7fff4ca25000 -     0x7fff4ca74fff  com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
   0x7fff4d921000 -     0x7fff4d931ffb  com.apple.CommonAuth (4.0 - 2.0) <16117F3D-4803-3A1E-8CE5-078245DB978F> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
   0x7fff4d945000 -     0x7fff4d95cfff  com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
   0x7fff4e489000 -     0x7fff4e4aaff4  com.apple.analyticsd (1.0 - 1) <5BEB8C96-A227-34D4-9F8C-2C06493C1C5B> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
   0x7fff4ea42000 -     0x7fff4ea52ff3  com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
