hi do any one know why after i created a schematic / export the netlist
and when i import the netlist in pcb layout it is always missing connections?
this happens even if i delete the connections in the schematic, reconnect them, regenerate the netlist and importing them in pcb layout again
the schematic file is here:
https://pastebin.com/XBFWsaFz
you would need to save that as test.sch
and the generated pcb file is here
https://pastebin.com/Gd7wivyN
you would need to save that as test.kicad_pcb
stock footprints are used for the components
