New to kicad. Cannot open kicad_pcb file
Hello I am new to kicad (i come from eagle and altium). But I have found this wonderful opensource project which I would like to work on, but I am strugling to just open the PCB file, so I figure it is somehting basic I have missed. however i cannot find a solution.
It is this project from github:
and heres a picture of the error i get
Any ideas how to fix it?
How did you download the file? Did you download it as a zip file? You could try downloading it again and see if it works.
hello thanks for the reply.
I downloaded it as zip. I did it several times. I also tried copying the “code” directly from the file in repository and paste it into a new document.
I am running Ki_cad on windows 7. Can you open the file?
I’m just in the process of rebuilding kicad but as soon as it’s done I’ll try
what version of kicad are you using? Is it a the stable release or a newer build?
I see from the image you uploaded that your using the stable release 4022. If you look at the pcb file as a txt file, because that’s all it is, it was created using version 5420. i don’t thing 4022 can open files created in newer versions. I could be wrong but I’ll install version 4022 now and try it my end. if that’s the case you can install a later build using the Kicad Win-Builder. There is, or was, a problem with it, but if you look on the forum, there is a fix that gets it working correctly.
Andy
Hello Andy thanks again for the helpful replys!
I will try to install the never version. Please tell me also if you get the file working when done building :slight_smile:
Hi Torben
I’ve have just tried opening the file using build 5504 and it opens fine so it must be because your using an older version
Andy
ok i’ve confirmed it. it will not open using 4022
Sweet thanks alot, great help!
I am not sure how to mark this thread as solved and “reward” you points for being awsome? :smiley:
You can add [solved] to the title of your original post. There are no rewards here I believe :wink:
it is possible to convert a newer version file back to the old verison by hand:
i have tried this some time ago and reported it at the yahoo mailing list:
https://groups.yahoo.com/neo/groups/kicad-users/conversations/messages/19485
hi epk,
you can fix this by hand -
i had the problem one time i send a file to http://pcb-pool.com/ (some of there cam operators have only the old kicad version - some have the newer versions…)
make a new project in the old kicad version and just save a clean Pcbnew file.
than open the clean file and the newer version ready file in an texteditor -
easiest way is if you can show them side by side - if you are on windows i recommend Notepad++ (http://notepad-plus-plus.org/) there are also a compare tool (Menu: Plugins - Compare - Compare [Alt+D])
than you can really fast see the difference in the header section - for example the layersetup.
(there are some other things - but i dont remember them - just try after each modification if it works :wink: )
you can change the settings with respect to the old version as example file…
with this i got my pcb (created in a current winbuilder version) file opend in the old version (download stable).
its i bit of work but can be done :wink:
sunny greetings stefan
