I installed KiCad a couple of days ago and cannot find any symbols to start a schematic drawing. Tried to go through library placements, tried to download new library files, and update paths, tried to add and append libraries in some table.
No symbols…how the heck do I get this thing working??
you need to add your libraries to this table. Use the browse libraries button to do so. (A file browser like dialog will open. navigate to your libraries and select the .lib files you want to add. shift plus leftclick can be used to select many libs at once. crtl plus leftclick can also be used to add files to the selection.)
It is however strange that this got not setup when you first ran kicad. Normally you get asked if you want to create the default library table when you open eeschema or the symbol editor for the first time. Is it possible the libraries are a separate package under mac osx?
