[quote=“c4757p, post:20, topic:9123”]
. . . . Titling the thread “what a mess” probably wasn’t the best start though, to be honest. [/quote]
Yeah, my mother used to look at my room (or, worse yet, my corner of the basement) and declare “This place is a MESS!!”
And on days when I felt brave I’d reply, “This mess is a PLACE!”.
@bobc, I was not aware they could be controlled from there, learning something new. Can you point everybody to how to get there?Just launching the control panel does not leave much clues…
(Editing the registry is not that risky if proper precautions are taken. One will find lots of Microsoft help that involves making such changes. Edit: May be I have gotten too used to deal with it, I could see novice users could mess things up if they were not sure about what they were doing. )
Thanks, @MitjaN, then users rather should use the control panel way to get rid of the environment variables installed by KiCad by accident than the registry entry edit I pointed to. (I added a note in the original post).
Seriously? Google it. You don’t know basic computer maintenance but advise people to edit the registry instead?
Ok, so tell us what those precautions are…! Editing the registry is always risky, and should only be done for specific and necessary changes. Your advice was wrong, unnecessary as well as dangerous.
Let’s look at a typical Microsoft example:
This article is intended for advanced users, administrators, and IT Professionals.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 How to back up and restore the registry in Windows
You obviously lack knowledge to give proper advice, I am seriously asking you to take a step back. It’s not just wrong advice, but dangerous. Please just STOP with bad advice!
What snowflake got offended by the word “mess” in the title of my post? If I want to convey to others that when you try to open a schematic with several several hundred symbols and all of them turn into squares with question marks - is a mess, I will jolly well do that! If you don’t like it, feel free to delete the name of the thread, to lock the thread or delete the post altogether but don’t add anything to that which was written by me. I appreciate your creativity, but do so under your own name!
