Unfortunately the two inner layer pads do not render when there is a zone connection regardless of the remove_unused_layers setting, This is a problem with the way the zones calculate the fill around a pad (clearance) and hole (hole_clearance), I have found that the resulting clearance around a THT pad connected to the zone on an inner layer is the greater of the clearance and hole_clearance. So, this constrains the size of the copper pad to be greater than the hole_size plus the hole_clearance * 2. So, a hole size of 0.3mm with a clearance of 0.2mm requires the pad to be at least 0.7mm to cover the clearance and should likely be slightly larger so that you do not create a seam at the intersection.
I wonder if it is a download issue? I posted two zip files with the same name. I think I should have appended the second upload with a version number or something to make it obviously different. I don’t know how this forum handles duplicate names. I changed the name by adding “v2” at the end and uploaded it here again.
nettie test.zip (21.2 KB)
EDIT: Well that is weird. I changed the name but I see it uploaded with the same file name as before. Maybe the forum compares to the other uploads and if it is a duplicate ignores it?
Another thought. What version of KiCad are you using? I used a couple different shapes to help me debug how the zones are being generated. I wonder if the “cloverleaf” is a result of the corners of a “rounded rectangle” of the smaller inner rectangle?
The cloverleaf is because @BobZ is using the fallback graphics mode rather than accelerated graphics, I think. (In fallback graphics, color blending is not well-supported, so you get artifacts where different shapes overlap. Rounded rectangles are drawn as 4 lines with rounded ends, overlapping in the corners, so the overlapping corners are brighter than the non-overlapping edge parts).
It seems you are correct although I do not remember setting fallback graphics. I wonder if that might be the default for some reason. My laptop seems to work OK with accelerated graphics and that cloverleaf is no longer visible.
I think that is asking for trouble in many circumstances. I usually think of e-mail attachments. You are never sure which you are viewing.
Anyway my responses here reflect a philosophy which I have been trying to keep. That is:
Just because I respond to a thread does not mean that I have all of the answers. I think that very often the original poster leaves open questions which are obvious to all but the original poster. So even if I cannot go much further than asking those questions I think I am likely to be helping the resolution.
In this particular case, the discussion got into some matters outside of what I know about KiCad. I appreciate that KiCad is open source, and there have been a few situations where I have managed to use a text editor to solve a problem. This although I thing I am not very skilled in coding or programming. That is what I did for the internal layer net tie, and I remember fixing another problem on a pcb design where some footprint somehow ended up a looooooooooooooooooooooong way outside of the normal field of view.
When turning off all layers and leaving only the paste layer, strangely, ring holes are always displayed, although only one layer is selected. Is this how it should be? 9.0.2
