NETLIST issue
Hi
I Have try for my first time to generate a netlist from schematic and I see that,
if in the library symbol properties, example in the field CASE in 2 different component
in the first one is type CASE without any final space and in the second one CASE have at the end a space, see picture below, the program use another field in the netlist, is possible to set some parameter to ignore the final blank space ?
3 posts were merged into an existing topic: NETLIST field issue
