Oh, a DRC issue. Why didn’t you say so in your first post?
Hint: http://catb.org/~esr/faqs/smart-questions.html
So I ran DRC and it complains a lot.
Then I simplified my test and it complained a bit less
In Pcbnew / File / Board Setup / Design Rules / Net Classes I made a “diffferr” netclass with a 0,888mm Clearance and 0.666mm DP Gap. and routed a diff. track.
The first 6 messages are just for the presumed “clearance violation”, but the last is a “Differential pair gap out of range” and it suggest that the value I entered for clearance (The distinguisable 0.888) as being the gap set in the design rules.
** Drc report for /home/paul/projects/kicad/aaaaaaaaaaaaaaaaaaaa/aaaaaaaaaaaaaaaaaaaa.kicad_pcb **
** Created on 2021-03-20 13:59:10 **
** Found 7 DRC violations **
[clearance]: Clearance violation (netclass 'diffferrr' clearance 0,8880 mm; actual 0,6660 mm) Severity: error
@(101,3700 mm, 66,3500 mm): Track [/asdf_P] on F.Cu, length 1,2898 mm
@(102,2820 mm, 64,7220 mm): Track [/asdf_N] on F.Cu, length 17,6360 mm
@(119,9180 mm, 64,7220 mm): Track [/asdf_N] on F.Cu, length 1,2898 mm
@(102,2820 mm, 65,4380 mm): Track [/asdf_P] on F.Cu, length 17,6360 mm
@(119,9180 mm, 65,4380 mm): Track [/asdf_P] on F.Cu, length 1,2898 mm
@(101,3700 mm, 63,8100 mm): Track [/asdf_N] on F.Cu, length 1,2898 mm
[diff_pair_gap_out_of_range]: Differential pair gap out of range (netclass 'diffferrr' minimum gap: 0,8880 mm; actual: 0,6660 mm) Severity: error
** Found 0 unconnected pads **
** Found 0 Footprint errors **
** End of Report **
I’ll post this now here. (14:04 local time)
My next step is to search on gitlab for this. If it’s not mentioned yet I’ll make a bug report for it (I have a nice test project now for it)
I’ll be back in 10 minutes or so…
14:25. It took me a bit longer…
I have created a new issue for this:
Please add some comments if you think the error report is incomplete.
