Net not appearing in netlist and hence not showing in PCB new
I am using a global label called DET which is connected to a header pin.
When I create the netlist, this doesn’t appear in the PCBnew.
Can you let me know what is incorrect in my assignment.
Incidentally I have similar global labels in the same header pin and they all appear in the netlist and in PCBNew
Check how it appears in the sch with a text editor, and check you do have a newly created NET file.
(ie rename something, to be sure)
The not connected cross on pin 6 is below R1 and the inductors pins. Always have some visible wire between pins and around junctions.
The same happens on P2 pins 1,3 & 7
I can only second that.
Many thanks for pointing out this - I will keep an eye to avoid such silly errors
