Negative area cutting into front copper layer
(All images are in one image at the bottom of the page, labelled A, B C and D)
I am trying to get this small Bluetooth module that I found online manufactured. I want to remove the antenna, thus just fabricating a board with all other parts and not the antenna.
I have downloaded the Gerber file from: I Made my own Audio Bluetooth module - Hackster.io
I have opened the Gerber file in ‘Gerber Viewer’, and some of the areas are now negative areas rather than ones which are cut out in the copper layer. Below A
I then tried to convert it to a kicadpcb file, and the same areas are not being placed or cut out in the copper. Below B
And therefore, when it comes to fabricating this, the PCB looks like this: C
Rather than this: D
Obviously, the removed antenna is purposeful.
I am new to this and would appreciate some help.
I am wondering if:
It would make a difference if I printed without these negative parts, and if it does, could someone please help me to work out how to fix this?
Thank you.
Post version information please. Help > About KiCad > Copy Version info
Version info:
Version: 7.0.1, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 5.0.1
FontConfig 2.14.1
libcurl/7.83.1-DEV Schannel zlib/1.2.13
Platform: Windows 10 (build 19044), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Mar 11 2023 03:41:46
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.83.1-DEV
ngspice: 39
Compiler: Visual C++ 1934 without C++ ABI
KICAD_SPICE=ON
