AZ-delivery’s DevKit C V2 had a slightly different shape than the one published by epressif.The only thing changed is the outline. V4 has the antenna on the top going out a little bit more than V2. V2 has small holes in the corners and extending a little bit more at the bottom (USB connector end) than V4.
Keeping that in mind I have used the V4 footprint in a design I’m working on at the moment. So far I have been too lazy to edit the PCB outline to reflect V2 dimensions. But as I will use V4 boards in future anyway, I might edit the footprint such that both boards fit. I’m new to KiCad as well, so this is not high priority for me at the moment.
I need the schematic and footprint. The library I have does not contain this device. Don’t know were to start of find and load the correct library. Thanks for both of you for the prompt replies.
I think you mean symbol and footprint.
You might try snapeda, I have downloaded the symbol and footprint there (have to be imported / added to the project after extracting).
