Good evening
I finished my hierarchical schematics (10 hierarchical pages), no errors, and I just imported it into the PCB editor.
I root manually, and there I would like to know how to easily find the blocks, because I have the impression that it is really all mixed up? (I have searching some components) reorganization manually or is there a more practical trick?
Thank you
What does that mean?
you can select a block of part in the schematic editor.
And it selects all these parts in the PCB editor.
There are several ways to select all footprints of a hierarchical sheet. From the schematic, in the context menu of the sheet box. Inside a sheet, just use box selection; this requires cross-probing enabled in PCB Editor Display Options in Preferences. Or in the PCB Editor, context menu on a footprint â Select â Items inâŠ
When the footprints are selected, context menu â Pack and Move Footprints.
@bertrand_meneroud @eelik
Yes Indeed I just tested by selecting in the diagrams, itâs good. ![]()
@ML9104
I donât use an automatic router, I make my âhairâ lighter by removing GND, and I place my wires and vias manually, and I adjust little by little, until the components are tightened
Is there a better method?
thank you
Ah, get you. You meant ârouteâ, not ârootâ. Now I understand.
Yes, it helps if you pronounce ârouteâ ârouteâ, not ârouteâ. Then it wonât be confused with ârouteâ.
You need the IPA. We pronounce route [ËraÊt] because [ËÉčut] is a rude word here.
You mean âroudeâ?
Too late, should be sleeping alreadyâŠ
Just to calm things down, but I was really confused. ârootâ means a lot of things, specially in the Linux/UNIX world.
I thought the OP might be referring to the hierachical âroot sheetâ or something like that.
@ alls
sorry for my English
I think the correct syntax is: rooting PCB tracks
With my apologies if I offended anyone.
Far from meâŠ
To return to my initial question, is my method good?
No, it is routing PCB tracks.
No apologies needed. Root is an interesting term in Australian slang. As Retiredfeline writes; it is a rude word, but the past tense, as in âmy PCB is rootedâ means the PCB is utterly and completely beyond repair: only suitable to place in the rubbish bin. Fair dinkum! ![]()
Iâm Dutch myself. Never knew ârootedâ has rude implications in some English dialects. As far as I know âRootâ has a meaning of roots of plants, and extrapolated meanings such as the origin of a family (family roots), or having a lot of control over things (Being root on Linux / unix). And the orinal post confused me too.
Route is a chain of connections, possibly over roads. For more look it up in a dictionary. I had a paper version of Collins / Cobuild once but it went in the bin because flipping though all that paper takes so much time, and there are a lot of dictionaries on the internet.
