We need to be careful here. Lag is different from refresh rate. Lots of TVs do heavy processing on the incoming video to sharpen it up, brighten the colours, etc. Plus they typically try to use the cheapest possible chip set. This can introduce noticeable lag.
I’ve not noticed any lag issues on a computer monitor for normal desktop use (although I’m told gamers have to be picky). Mostly it’s about getting a flicker-free screen and judder-free scrollling and motion.
These days it’s probably also common to use big TV’s a s displays for game consoles. Which produce excellent video quality by themself, do not need “heavy processing” but do benefit from low latency.
It’s probably possible to disable or at least influence the amount of processing / lag of many TV’s, but you’ll have to read the manual and it’s probably written in some obscure language intended for nitwits. But then again, the cheapest TV’s may be stripped of any possibility to output a decent picture.
Talking about terrible lag…
Here in europe there is some thing called soccer, which is apparently quite popular. Apparently lag was bad enough sometimes that people heard a lot of noise and cheering from houses around them, before they saw on their own television whether a goal was made or not. Apparently there were several seconds difference in lag, depending on the route of the TV signal to your home.
10 minutes for the UK sourced news in Malaysia, in case the story is sensitive.
Anyway the point is that broadcast television is not “interactive” (except for the New Year countdown) while CAD is
Yeah, in my opinion dual monitors is definitely the way to go!
(And I don’t mean like the 1980’s CAD stations, where a large monitor displayed your work while you entered commands and did housekeeping on a second, small, monitor.)
At various stages of a design effort I may have:
A circuit simulator on one display, and KiCAD Schematic on the other;
Schematic editor on one side, and data sheet(s) on the other;
Schematic editor on one side and PCB layout on the other;
PCB layout on one side and footprint editor on the other;
Different versions of a schematic or layout, one on each side.
Rarely, I’ll stretch a schematic or layout across both monitors so I can get a more complete perspective of “the forest”, after concentrating on the details of “the trees”.
For the last year, I may have a videoconference on one side and related document(s) on the other
It’s the digital equivalent of the Good Ol’ Days (formerly known as “these difficult times”) when I covered half the acreage of a drafting table with data books, application notes, reference manuals, and product samples, leaving barely enough room for whatever I was working on.
I have a pair of 10.5"x18.5" (22" diagonal) monitors set side-by-side. I usually position my chair so I’m mainly in front of one, with the other more in my peripheral vision, an easy head-turn to the side. One guy at work likes dual monitors stacked vertically. There’s probably lots of room for perceptual psychologists to investigate the effects of spacing and physical arrangement.
I used to have 2 monitors back in the dark ages…life was terrible and replacing one monitor periodically at a time was a huge mistake I can now see in hindsight that always resulted in different drivers, sizes, res and problems. As a mechatronics engineer working on several mech, electronic, graphic EDA’s I made a leap of faith about 7 years ago now…to go to a single 34" wide Samsung curved L834790CN8 monitor and my graphic life is so much better now…my focus is now solely on the design issues not on how to view it also. If you do anything more graphics wise than playing games then I assure you of great advice. Even my laptop can plug into the HDMI2 of the monitor so that a portion (25% in my profile) is auto displayed as PIP on the monitor. Add the Microsoft PowerToys FancyZones (win10 although I believe this will be std in Win11) life is as good as it gets to have some apps just auto open up in a section I preallocated…such as dev systems and main browser goes to right half of monitor and then Outlook to left 1/2 etc.
So if you even vaguely think that your monitor is much of a sticking issue focus then I cannot highly enough recommend the items above…large good monitors might be a touch more expensive however I have done some amazing things for 7 years and cannot ever see an upgrade coming for a very looong time.
Driverwise and resolutionwise to keep up with latest trends & apps it’s had a perfect score. Reliability it’s been almos perfect…only two issues that every now and then the screen auto off stops working however that’s has been a Win10 issue so easy to fix. Second issue is that the screen after a few years stopped coming out of hibernation but googling pointed to a failing power supply. This was easy to fix as the power supply is external and getting one for $100 through the web was as easy fix.
Looking at engineers and graphic design desks often I always see a bunch of monitors and smile that the secret is not yet out even after so many years?
Also I work on embedded linux systems and then plug the linux into hdmi2 rather than my laptop. I can devote a certain percentage of the screen as PIP to the embedded then. Pared with a logitech mouse/keyboard I can copy/paste across the different systems on one monitor.
A widescreen monitor is too nice. I use a 27" 1440p noname monitor from Monoprice, it was relatively inexpensive and a huge improvement from my previous Dell 1400x1200 monitor. When shopping for a CAD monitor, if possible, look for something that has FreeSync or VSync or whatever frame tech your graphics implement. I have a FreeSync monitor and I have absolutely no tearing when using KiCad.
For additional space, I use Barrier, a software KVM. It lets me share my mouse and keyboard with my Apple laptop, and I place the laptop next to the monitor. I have datasheets, parts catalogs, etc. on the laptop and can dedicate the entire PC monitor to KiCad. It’s like having two monitors, my clipboard is shared between the two machines, I just can’t drag windows between the monitors, but that ends up being more of a boon than a disadvantage.
