Normally I do not post screenshots of my full desktop.
I do not know about KDE Plasma, but my Linux Mint box has no trouble with dual or even triple monitors. I can just mix and mash in the monitor settings.
My current PC is an old i7-860 (Yep, first gen.) I got for free with some radeon video card from probably also that era. I honestly do not know what videocard is in this PC. I never bothered to pay much attention to it, it just works.
A bit of poking says:
paul@medion:~$ lspci
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Juniper PRO [Radeon HD 5750]
when working with Pcbnew, it is usually maximized on the right monitor, and the left is a mishmash of other stuff I want to keep handy. From web browsers to datasheets and schematics. If you select a footprint in Pcbnew, then the schematic instantly pans to that location, (and also the other way around) which is very handy during initial component placement. The black ares on the left are non existent areas, because the portrait monitor is higher then the landscape monitor.
My HP LP2465 monitors have a resolution of 1920x1200 and a measured diagonal of the display without bezel of 610mm.
Pitch is:
520/1920 = 0.2708333333333333
Which is a bit coarse.
A pitch of 0.22 would be nearly optimal, and when pixels get below 0.18mm it starts becoming a gimmick (you start scaling text and even icons because they are to small otherwise).
@craftyjon
Have you ever tried putting one monitor in portrait?
520mm/ 2560 = 0.20mm pitch which is indeed close to the minimum usable pixel size. I would like a 4k monitor myself, but it has to be 107cm (43"). 4k for a 86cm (32") results in too small pixels. Such a monitor would be about similar in width as your current dual monitor, but with more vertical pixels.
