I have a small pcb done in Kicad and it works. We buy a small panel of 5 and cut them by hand. We would like to make a big panel and have Seed vcut (vscribe?) arround each board on a panel of 200.The board is tiny btw 6.75x18.5mm.
I recently found panalize.py that is susposed to run in the python script window but I can’t get it to work. I am not sure but it may be a path problem. I am not sure where to put the panalize.py file. its at C:\Users\david\Documents\Kicad\panelize.py and the file I want to panelize is at C:\Users\davidC:\Users\david\Documents\dock2\dock2.kicad_pcb. I usually get errors saying ‘panalize’ is not defined or a syntax error pointing to the : in C:… when I try different combinations. It looks like python is living on drive D: (“D:\Program Files\KiCad\lib\python2.7\site-packages\wx-3.0-msw/wx/py/path.py”, ) but I can’t seem to cd to C:\ to get to C:\Users\davidC:\Users\david\Documents\dock2 where my file is.
Any suggestions?
