UBUNTU
install mysql, mysql odbc (…)
- create a database
- create a file “mysql2.kicad_dbl”
- add file to kicad library in kidad lib manager
-- phpMyAdmin SQL Dump
-- version 5.2.1
-- https://www.phpmyadmin.net/
-- Host: localhost
-- Creato il: Feb 10, 2024 alle 11:34
-- Versione del server: 8.0.36
-- Versione PHP: 8.2.10-2ubuntu1
SET SQL_MODE = "NO_AUTO_VALUE_ON_ZERO";
START TRANSACTION;
SET time_zone = "+00:00";
-- Database: `kicad`
-- Struttura della tabella `Capacitors`
CREATE TABLE `Capacitors` (
`CA` bigint UNSIGNED NOT NULL,
`Part_ID` text COLLATE utf8mb4_unicode_ci,
`Manufacturer` text COLLATE utf8mb4_unicode_ci,
`MPN` text COLLATE utf8mb4_unicode_ci,
`Symbols` text COLLATE utf8mb4_unicode_ci,
`Footprints` text COLLATE utf8mb4_unicode_ci,
`Description` text COLLATE utf8mb4_unicode_ci,
`Value` text COLLATE utf8mb4_unicode_ci,
`Capacitance` text COLLATE utf8mb4_unicode_ci,
`Voltage_Rating` text COLLATE utf8mb4_unicode_ci,
`Capacitance_Tolerance` text COLLATE utf8mb4_unicode_ci,
`Dielectric_Type` text COLLATE utf8mb4_unicode_ci,
`CasePackage_Size` text COLLATE utf8mb4_unicode_ci,
`Verified` int DEFAULT '0',
`Cost` decimal(10,0) DEFAULT NULL,
`Mass` double DEFAULT NULL
) ENGINE=InnoDB DEFAULT CHARSET=utf8mb4 COLLATE=utf8mb4_unicode_ci;
-- Dump dei dati per la tabella `Capacitors`
INSERT INTO `Capacitors` (`CA`, `Part_ID`, `Manufacturer`, `MPN`, `Symbols`, `Footprints`, `Description`, `Value`, `Capacitance`, `Voltage_Rating`, `Capacitance_Tolerance`, `Dielectric_Type`, `CasePackage_Size`, `Verified`, `Cost`, `Mass`) VALUES
(1, 'CAP-002', 'Murata', 'GRM0335C1E100JA01D', 'Device:C', 'Capacitor_SMD:C_0201_0603Metric', 'CAP CER 10PF 25V C0G/NP0 0201', '${Capacitance}', '10 pF', '25 V', '+/-10%', 'C0G', '0201', 0, 2, 3.6),
(2, 'CAP-003', 'Murata', 'GRM0335C1E100JA01D', 'Device:C', 'Capacitor_SMD:C_0201_0603Metric', 'CAP CER 20PF 25V C0G/NP0 0201', '${Capacitance}', '20 pF', '25 V', '+/-10%', 'C0G', '0201', 0, 2, 3.6);
-- Indici per le tabelle scaricate
-- Indici per le tabelle `Capacitors`
ALTER TABLE `Capacitors`
ADD PRIMARY KEY (`CA`);
-- AUTO_INCREMENT per le tabelle scaricate
-- AUTO_INCREMENT per la tabella `Capacitors`
MODIFY `CA` bigint UNSIGNED NOT NULL AUTO_INCREMENT, AUTO_INCREMENT=3;
COMMIT;
odbc drive call direct a file (no odbc.ini)
DRIVER={/usr/lib/x86_64-linux-gnu/odbc/libmyodbc8a.so
username e password in connection string
mysql2.kicad_dbl
"meta": {
"version": 0,
"filename": "mysql2.kicad_dbl"
"name": "MYDatabase",
"description": "A database for testing purposes",
"source": {
"type": "odbc",
"dsn": "",
"username": "",
"password": "",
"timeout_seconds": 2,
"connection_string": "DRIVER={/usr/lib/x86_64-linux-gnu/odbc/libmyodbc8a.so};Server=127.0.0.1;Database=kicad;User=user1;Password=password;Option=3;"
"libraries": [
"name": "Capacitors",
"table": "Capacitors",
"key": "Part_ID",
"symbols": "Symbols",
"footprints": "Footprints",
"fields": [
"column": "CA",
"name": "CA",
"visible_on_add": false,
"visible_in_chooser": false
"column": "Manufacturer",
"name": "Manufacturer",
"column": "MPN",
"name": "MPN",
"visible_in_chooser": true
"column": "Value",
"name": "Value",
"visible_on_add": true,
"column": "Dielectric_Type",
"name": "Dielectric",
"column": "Voltage_Rating",
"name": "Voltage Rating",
"column": "Cost",
"name": "Cost",
"column": "Mass",
"name": "Mass",
"properties": {
"description": "Description"
