It’s supposed to be in the status bar but something was overwriting that on Windows. I just fixed it.
That is your opinion.
I don’t think it looks any different at all (in terms of general appearance); only the placement of the same things has changed. However, in fact, that will make the project on my machine needlessly take up substantially more screen real-estate.
The bottom area can be hidden if you don’t use the calculator, image converter or worksheet editor often. They are still found in Tools menu.
Right now I am working on 2 boards for a system that need to communicate with each other. Being able to drop back to the Project window allows me to focus on just one instance of KiCad and bounce between the designs of the 2 boards.
I know that I can run 2 instances of KiCad at the same time, but that makes the proper tabs hard to find when switching between some tasks.
The current V5 configuration takes up less than 1/4 of my screen and contains the complete names/paths of everything.
That is a good idea. How do you do that? I find that I cannot adjust the vertical and horozontal size of the window (below a minimum amount that is bigger than what is needed) to hide those icons - perhaps not working as intended? (same version as above).
[For the record of the thread the window size problem is reported fixed in the split out thread.]
Edit: I notice these last posts display 3 different KiCAD versions. Perhaps time to enforce quoting version info in the posts?
Are you guys naming all your projects the same? The titlebar of the application shows the project name first (and intentionally)…show its visible in Explorer, Task Manager, Alt-tab, Windows-tab, etc
Can we keep this thread to positive suggestions please.
I know icons an issue that generate a strong opinion, but will all refrain from personal attacks
3 posts were merged into an existing topic: Discussion about the new project view layout
I’ve just started on my first real project in V5.99, and I wondered If I did an intermediate save, and staring at the save icon did not help much, so I pressed [Ctrl + S] and the floppy icon changed from grey to a lighter shade of grey
Maybe someday I’ll get used to these new icons but I find them all far to similar with not enough use of colors.
KiCad also shows the name of the project in the title bar, and it’s common practice to add an asterisk if the file has changed, but KiCad does not do this. Hmm, that may be worth an Issue on gitlab (Have not checked yet).
Yeah, I agree. The old icons were not great, but at least they were explicit.
The new icons are pretty, but not explicit at all.
The component or footprint editors icons do not have a pen or something to tell it’s to CREATE something. -> The icons present in the eeschema and pcbnew toolbars are GOOD, they have a red pen on them, please use it in the main app.
The view Gerber icon is not different from the edit PCB icon.
The Save icon is black when needs saving -> no ! black has no meaning ! it should be green, blue, or red.
Oh, also… PLEASE support dark themes
Look at how look the toolbars in Pcbnew :
Hello!
It is clear from the start that colors were not chosen with logic in mind.
Actually remembering 8 icons is indeed a challenge!
We are talking here about a software which is extremely well designed, and which
has been developed over many years, which represents thousands of hours of work.
We are talking about a free software with outstanding support, where any question
or problem is addressed 24 / 7 within hours when not within minutes.
We are talking about a great deal of voluntary work, all of it provided for free.
And what is these days’ criticism? Icons!
You know that proverb? When the wise points to the moon, the idiot looks at his
finger. I can’t help seeing a connection with this thread.
You’re right, a dark theme will completely change the world when it comes to PCB
design.
I should have started with this: many thanks to the developers and to those to keep
this forum alive and always bother replying to my silly questions.
R
Seeing as Kicad’s release schedule is a full new release every year (Thanks Developers. You freaken rock!!!), I wouldn’t worry about fashion in two year’s time. They can change again in two years.
I’m not quite sure how to read this comment, Brian,
If you mean “the icons can change again in two years”: I don’t think anyone involved with this site would be particularly enamored with that idea (masochists excluded).
If you mean “fashion will change and keep changing”: then that is the point I was making. Colour choice needs to be above fashion, so, two years down the track, Kicad doesn’t receive comments such as “the icons look a bit dated”.
yes I mean the icons can change with the fashion… changing icons with major releases I think is a wonderful way to ensure people notice that they have stepped up to a fresh new version and create a very natural way to know which version you are working in for people that have old versions installed for legacy support. In addition it keeps the design fresh and current with whatever trends are gfoing on with UI design (I tend to not like new UI designs myself but whatever… not my baby). They changed many of the icons from kicad 4 to kicad 5. Makes sense they do the same from kicad 5 to kicad 6.
This was what kicad 4 looked like
This is what Kicad 5 looks like
Don’t sweat the small stuff. This is BikeShedding stuff. I don’t care what the icons look like. Just make a kicka$$ open source program I can use both at work and home without needing 3 licenses and 30 thousand dollars.
man… you were remotely reading my mind… complaining about icons is a waste of time for every single resource, whether the dev team or the HW on which this forum is hosted…
@elekgeek Don’t forget to update your avatar once you start using v6 on the regular.
You might wanna start with yours
Hello All, not sure to be on right place ? So, I download the nightly release of Kicad 5.99 and was surprising by the (new ?!!?) size of the Kicad main menu. On version 5.1 is :
with 5.99 :
Here as you can see I reduce to the minimum the icons size, but personally I would prefer the 5.1 icons style. Is there a way to apply this on 5.99 ? Or is it on the pip to do it ?
Thanks.
Current version Info is :
Application: KiCad
Version: (5.99.0-10293-g7c64dba333), release build
wxWidgets 3.1.4
libcurl/7.74.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19042), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Apr 14 2021 12:03:23
wxWidgets: 3.1.4 (wchar_t,STL containers)
Boost: 1.75.0
OCC: 7.5.0
Curl: 7.74.0-DEV
ngspice: 34
Compiler: Visual C++ 1928 without C++ ABI
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Due to licensing issues, we have replaced all the icons with correctly Creative Commons licensed icons.
KiCad is not a python application, pip cannot do anything to change it.
