Multiple Vias On Track - Turn off "helpful" track replacement
I have a high current track as shown in the picture and wish to use mutiple vias to switch layer. Unfortunately when I try to do this pcbnew always replaces the track so only the last via is actually doing the current transfer.
It’s trying to be helpful, but it isn’t. :slight_smile:
Regards,
Andrew
You can turn off the “Auto-delete” in your General Settings. You can also edit the track that you want to keep and lock it. This should prevent it being deleted.
Ah only in default is there a “lock”… and it doesn’t work. When I laid the track over the top it deleted all the vias.
Unsure which “auto-delete” you’re referring to in General. I can’t see it.
Thanks Rene!
The checkmark in General Settings is called “Delete unconnected tracks” (it controls the same button as Rene shows).
I’m toggling that, it still does it!
