Im working on a display port switch as part of a bigger project. I created a bus alias for DISPLAY_PORT
As I went to route the board, I realized that the buses were not really working. the signals with the same label, in the same sheet were all connecting together, and the signals were not connecting to the hierarchical bus labels since they were not exactly the same as the alias.
The only work around I could think of here would be creating 3 separate bus aliases, which would create 3 independent copies of the display_port
sheet.Is there a better way to do this?
