I am not sure I am asking this right. Being a software guy mostly I am trying perhaps force hardware into the same idea
I am making a few boards with a few minor different variations. All of the boards contain a few “sub systems” that are exactly the same. IE: power schematic is the same on all. Vs. maintain 3 different schematics for all variation designs. I would like to be able to create this power schematic. Then just reuse that in all designs. Sort of import or link them. This way I could update the “master” if needed and then pull in changes to all over schematics. Is this something kicad can do?
As far as I know you can’t do this with Kicad. It basically one schematic/PCB per project. If you need to have variations then you will need to have a seperate project for each. They will also not be linked.
If your are talking about schematic only without having pre-routed bits for the PCB, then you could use hierarchical sheets for that. In the power part example, your sheet will have two inputs (VIN, GND_IN) and two outputs (VOUT, GND_OUT) and all components for this power part will be inside of the sheet.
Now you only need to use the same sheet for all the designs that require it.
