Multiple busses from one signal
Hi all,
I’m designing a schematic using a Realtek RTL8367RB-VB Switch Controller. Pins 92-94 are used for SPI Slave Management Interface or EEPROM SMI Interface Data, depending on the configuration. I want to have headers for multiple busses, one for each configuration (shown in pictures below). However, the ERC keeps telling me “Label not connected to anything” for all of the pins. Is there anyway to fix this? Thank you!
I have never used buses with labeling them (I use buses only as graphic elements).
SPI1.SCK seems having no problem.
May be SP1.CIPO should be SPI1.CIPO.
Yes you’re right! That’s a bad oversight from myself, thank you Piotr.
