I’m building an FPGA board that needed several DC-DC supplies. I used hierarchical sheets, each sheet contains an identical copy of DC-DC step-down circuit. Since each supply has a different output level, the voltage divider resistor values has to be different, therefore the subsheets are instantiated from different sheet files (but with identical connection, footprint, etc). I’ve routed one DC-DC block, generated rule areas for all four blocks. The multichannel tool will report topology mismatch for the DC-DC blocks.
I’m curious about two problems:
- Do I have to instantiate two subsheets from the same file, in order to make multichannel work? If so, what should I do to make different sheets have a different voltage divider?
- Is there any chance to see what “topology” is really mismatched? Shall I make this a wishlist item?
Thanks for all your assistance.
Minimal reproduce project archive:
replicate_dcdc.zip (810.3 KB)
Version:
Application: KiCad PCB Editor arm64 on arm64
Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.7.1 (SecureTransport) LibreSSL/3.3.6 zlib/1.2.12 nghttp2/1.63.0
Platform: macOS Sequoia Version 15.3.1 (Build 24D70), 64 bit, Little endian, wxMac
OpenGL: Apple, Apple M4, 2.1 Metal - 89.3
Date: Feb 19 2025 13:05:44
Boost: 1.87.0
OCC: 7.8.1
Curl: 8.7.1
ngspice: 44.2
Compiler: Clang 16.0.0 with C++ ABI 1002
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: Simplified Chinese (Mac OS)
Num: 1,234.5
