When looking at a multi sheet schematic with buses or nets that cross over different sheets, how do you determine were the other connections are?
For example, I was looking at the demo project video and the sheets have nets that cross over different sheets but not being familiar with the design and was useing the schematic to troubleshoot an issue how could I trace the net?
The current solution is to highlight the first net-segment and than switch through all other sheets and look if there are also highlighted nets.
If you find this not satisfying enough you could upvote gitlab-issues which want a new feature to show all connected nets. I think there are currently 2 issues open (one as an extra feature, one as a extension to the find-dialog):
