Dear All,
I have a problem, with my project since I upgraded to KiCAD 7.
I have a communication PCB, wich will be connected to an other PCB, called ‘Connector PCB’.
The Connector PCB had been exported to VRML, and I want to use it for the communication PCB as an extra 3D model for a specified footprint.
This way worked well in the previous version.
Now, if I try to load the WRML model of the Connector PCB, in the 3D viewer I can’t see anything. If I generate STEP format from the Connector PCB, than it can load in the PCB viewer.
The generated WRML model can load to the FreeCAD well, but my problem, if I try to export it to WRML from the FreeCad, I can load in the KiCAD 3D viewer, BUT the electrical part 3D models are in an other point, out of the PCB layout.
The exported WRML model from FreeCAD:
The origial exported ConnectorPCB.wrl can’t loaded.
