Moving reference files in components
Just started using KiCad, creating my first component. Really simple question, inside the component library, my U reference field and Value reference field are located in the middle of the component and on top of each other. I can move them but I can’t seem to get them to not be right on top of each other. In the help I found online, it seems they can be placed independently, say one at the top of the component schematic and the other at the bottom, but I can’t figure out how. Can someone please give me a hint?
Thanks!
If the two are superimposed, you can’t just use a “rectangular selection”, since both would be affected simultaneously.
The following methods will show a disambiguation menu:
  • Right-click on the reference, choose “Field Reference”, then choose “Move Reference”, and reposition the element
  • Press “m” to select the Move Tool, then left-click on the reference, choose “Field Reference”, and reposition the element
Does that help you?
Hey, that worked! I knew I was missing something simple.
Thanks!!
